| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
10-28-2006, 10:31 AM
VA
Cobra Make, Engine: Superformance #095, w/ 1966 428
Old style brakes
Does anyone know what the Ford front disc brakes which came on the early SPF cars came from/cross over to?
10-28-2006, 10:42 AM
Il
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
I have later #, but I think the early ones used Granada( not the Fox one, but the earlier version that had the Monarch and Versailles as sister cars) rotors. Have you checked www.performanceunlimited.com ? They have a tech section on SPF's and it may be listed there. If not, I'm sure Bill Wells or one of the early numbered car owners will pop in.
WDZ
10-28-2006, 11:18 AM
Mi
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
I was told Ford Granada, as described by Woodsy ..but have never checked mine to verify . Willwoods back then in the very early cars were an extra cost option, later made standard. Quite a few of the early cars supposedly upgraded for the extra cost Willwoods. Bill.
10-28-2006, 03:23 PM
VA
Bill,
Do you know what year Granda? If I change over to the Willwood do I need to change the disc also?
10-28-2006, 04:03 PM
Il
I'm not Bill, but do know that all the mid 70s to early 80s(prior to the Fox version) Granadas/Monarchs/Versailles used the same rotor. Just pick a year.I believe the Wilwood package is a complete Rotor/caliper changeover.
WDZ
10-28-2006, 05:09 PM
VA
better brakes
I know I have to change to the new SPF caliper mount  but the car allready has nice 11' rotors/hubs with new bearings. I wold like to mount these Ford Racing calipers  if they have the same mounting spacing as the Wilwoods. Woddz428, I think you are correct about the calipers I have now. According to Motorcraft they fit 82 different Ford applications from 83 to 93. If I can find what other applications the Wilwoods fit, then I could see if the Ford racing will cross-over and swap, and if I can mount the new SPF bracket on my old steering nuckle (which I think I can) and use the same rotors. Then I would be happy  ... but it's never that easy right?
11-02-2006, 10:47 PM
TX
Cobra Make, Engine: Superformance 514 ci
I just ordered the Willwood upgrade for #569 from Dennis Olthoff. His kit does not have (and therefore I am ASSUMING they do not require) new rotors. It comes with calipers, pads, new steel braided lines and bracket. I am having them installed this week while I am up in Seattle. Can't wait to get the car back soon and see how they feel. They HAVE to be better than the Granada's even though I have never had any meaningful problems with the old ones.....but I never tracked the car so never needed real hard braking....YET....LOL
Uncle Fester - Yes I REALLY did say that
11-03-2006, 11:56 AM
VA
Gary,
If it's just a matter of swapping the bracket, calipers, lines and pads the job is a piece of cake. I think the new cars using Wilwoods are running 12" rotors. They are GM and you can get them locally. You may want to check with Dennis about this, but if he thought you needed them he would have included them in the kit right? It would not cost too much more to replace them while you are there. Please let me know how it turns out and the cost of the parts.
Thanks,
Tom
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
