12-19-2006, 08:57 AM
Engine mounts with less movement?
I have polyurithane mounts on my small block. They move too much and the side pipe will touch the fiberglass were the bend comes out the side on hard acceleration. The mounts look to be this type sold on summitracing.com.
Does anyone have these? I found them in a search in relation to this thread.
Do these fit the superformance? In relation to this thread.
12-23-2006, 12:33 PM
solution
edit for review
12-23-2006, 05:18 PM
NJ
Cobra Make, Engine: ERA 427 SC with 428 PI
put a 1/4 " spacer under the right side mount and the problem is solved
"Is it original ?" -- " Yes! But some parts are new."
It's just easier this way.
12-23-2006, 09:39 PM
MI
Greg,
I have the Olthoff mounts. These work well and there's no problems with the pipes hitting the body.
Jim 1855
12-24-2006, 08:45 AM
I sent an image of my type of mounts to the Olthoffs. I'm waiting their review to see if their mount has less movement. I'll probably just buy a set from them when they reply, but I don't know what their unit looks like.
I lifted the right side with about 3/16 spacer set on top of the car frame to align the side pipe in center of hole in body. I also recently made a set of these, one for each side of the polyurethane. It stops the movement by about half under hard acceleration. The passenger side which pushes the pipe downward is fine.
The right driver side lifts pretty hard to completely smash the polyurethane.
01-09-2007, 09:14 PM
AB
Cobra Make, Engine: #901 Superformance 427cid 540hp!
SWI custom mounts
Hi Greg
I manufacture the SWI custom engine mounts for the small block SPF cars. The polyurethane SWI engine mount will elimate "ALL" unwanted engine movement "without" transmitting harsh vibrations to the cockpit.
Please feel free to contact me and I will send you a set for your inspection and installation.
Rod
rodscobra@shaw.ca
"This year Ferrari's Ass Is Mine"
01-09-2007, 09:34 PM
AB
SWI SPF engine mounts
Please look in my gallery for photos of the SWI custom engine mounts.
Thanks again
Rod
01-11-2007, 04:36 AM
Thanks again
Rod
Hi Rodney,
Please call me 480-661-0111.
I have questions about the engine mounts.
Greg
02-02-2007, 05:42 PM
Do the Olthoff urethane engine mounts make a noticeable difference? I'm going with a Windsor motor and I'm wondering if it's worth buying the engine mounts for a new install. Besides the cost, is there any downside?
Doug
02-02-2007, 05:59 PM
MI
Cobra Make, Engine: Superformance Cobra SC, 514CID
Doug
I have installed the urithane mounts in many Superformance cars, as well as my own. In my opinion, they are a must
. Less engine roll helps prevent wheel hop
. Less engine roll helps safe guard pipes from hitting the body
. Because of their construction the poly mounts can not seperate.
. The poly will not settle like rubber.
The mount itself is an Energy Suspension part. What Olthoff offers is and adaptation for your Windsor engine in a SPF. Well worth the money IMO
Craig
02-03-2007, 11:30 AM
Here are my old mounts that let the pipes move enough to hit the body. I guess it depends how much power the car has before you look for something with less movement.
02-03-2007, 11:11 AM
Doug
I'd like to see a picture of the Olthoff Windsor mount. If you find out what they look like let us know.
02-02-2007, 06:18 PM
Thanks Greg! I'll give Olthoff a call on Monday.
05-11-2007, 07:07 PM
RI
Cobra Make, Engine: Superformance #1676
I've got the mounts from Rodney in my SPF.. I love em'
Feel free to contact me and I'll tell ya more about them! You will not be disappointed!!
Sean
05-12-2007, 02:32 PM
Tex
Cobra Make, Engine: SPF2004 Roush 427R
Sean, i just ordered a set of mounts from Rodney. Any advice or problems with install. Dave SPF 2004 Roush 427R
05-12-2007, 02:50 PM
RI
Dave,
I installed my mounts from new and had no issues, I've got over 4k miles on them so far and very happy ..... Be sure to follow Rod's instructions and I'm sure you will also be pleased with them.
Sean
05-13-2007, 08:43 PM
I took a couple of pictures of the Olthoff engine mounts for the 351.
http://www.clubcobra.com/photopost/s...0&ppuser=26014
Planning on dropping them off at RED in Reno next week...Steven is going to start the install soon  .
05-13-2007, 09:11 PM
VA
I have used both of these mounts in my Superformance. Either of them will solve your problem and limit engine twisting. I drive my car a lot (working on 43,000 miles). I found Rodney's, though strictly speaking not "solid" mounts, transfered a noticable amount of engine vibration through the steering column/wheel and added fatigue in a short period of time. The Olthoff mounts offer the same, or nearly the same benefits, but with very little increase in vibration over the stock mounts. Rodney's mounts are beautifully crafted and look great. If I were going to just show and or drag race my car, I would choose his mounts. For driving (street, road and drag racing) I personally prefer the Olthoff mounts. Your mileage may vary.
05-14-2007, 06:58 AM
I just installed the Olthoff mounts after my sidepipe bracket on the passenger side kept breaking. In addition to stopping the breakage, it has made a tremendous improvement in that the car feels more solid, more responsive, and it doesn't shake at idle like it used to.
I thought it was the BB torque that did this in the SPFs but obviously not...
Highly recommended.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
