Old 02-03-2007, 11:04 PM
double ugly's Avatar
Default Older SPF vs: newer SPF
This has been brought up before, I'm sure but... What are the differences good and bad from the early SPFs and the later ones. An SPF made in 2000 must have had some flaws that were improved upon in later years. Thanks, John
double ugly
Old 02-03-2007, 11:22 PM
Got the Bug's Avatar
I booked marked this CC thread when I was researching pre-owned cars.
SPF Changes
http://performanceunlimited.com/supe.../features.html
Old 02-04-2007, 06:02 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
Double...
Here's another thread that answers the same question....
http://www.clubcobra.com/forums/showthread.php?t=75497
I personally would not confuse "Flaws" with user friendly improvements !!
Old 02-04-2007, 06:29 AM
Did I say flaws? Oops. I meant upgrades. I've found a 700 series that I may be able to purchase for under 45K. Seems like a good car.
double ugly
Old 02-04-2007, 07:09 AM
A friend of mine has one of the early cars, about #50, with a 351W and Tremec. Anyways, he has had recurring problems with a leaking hydraulic throw-out bearing, so he went to install a slave cylinder with a clutch fork, but it wouldn't fit because the frame was too narrow in that area, so the frame had to be notched. Also, because he didn't want to take the interior apart to pull the tranny, I think mainly pulling the tunnel off, he had the tranny crossmember cut out so the tranny can be pulled from the bottom, and now the cross member is a bolt in. Also, the diff on the earlier cars is not mounted as securely as on the newer cars, and some people who have drag raced their cars alot have had problems with the diff mounting bracket breaking, and needs to be rewelded, or, reinforce the bracket if it has not already been done so.
If you have a choice, I would think a newer one would be better, although they are all fine cars.
Is the new diff as good as or better than the ford 8.8 they were using for such a long time?
Old 02-04-2007, 07:19 AM
Woodz428's Avatar
There is not enough info, but I would have to believe it is as good or better. It is an Australia Dana center section. The change wasn't done because of any issues with the 8.8, but with availabilty of a center section that is no longer made. The BTR pumpkin is the same one that has been in the Coupe from the begining and it was just a production change over to make sure they would have a continuing supply.
WDZ
Old 02-04-2007, 07:45 AM
Originally Posted by double ugly
Did I say flaws? Oops. I ment upgrades.
I knew what you meant, I think 95% of the upgrades are to improve the vehicle like Blistein shocks, willwood brakes, lowered floors, emergency brake, heater box, soft top...and things like that. There have areas that needed upgrading like Windshields cracking and loosened axel nuts, Knockoff spinners that SPF has addressed and changed.
Old 02-04-2007, 10:08 AM
SP01715's Avatar
My initial feeling would have been the Dana unit would be better, but I recently broke a Dana 44 in my 03 Jeep Wrangler running a stock motor with 33's and a fairly mild lift. I have not had a problem on my SPF with A LOT more hp and torque so who knows. I think Dana still makes a hell of a product but in might not be any stronger than the 8.8 Ford (unless you go with Dana 60 parts).
Old 02-04-2007, 11:45 AM
Banned
John, I personally chose a 700 series car because it had all the nicer upgrades one would want: lowered driver's footwell, 4 wheel Wilwood disc brakes, cool air vents for both footboxes, chrome roll bar. I eventually swapped out the factory AVO coilovers for the Bilsteins and the car rides so much better. Also, the "older" windscreens are now being used on the new "Shelby" version of the Cobra, so availability is no longer a problem. Finally, with the right offsets you can still squeeze a lot of tire under the wheelwells (some report 315s, others claim to fit 335s). As for me, I plan to install MT drag radials (325/50-15s) and won't have any clearance issues (with my already modified inner hubs and soon-to-be one inch stretched inner flanges). Under $45K is still a good value if the rest of the car has been well taken care of.
-Dean #747
Old 02-06-2007, 12:11 PM
Madmiles442's Avatar
I have 2000 #867 and would love to have the Bilsteins. I have 335 Michelin Pilots out back and they don't rub. I'm upgrading the rear sway bar and installing urethane bushings. Other than that, the only things I've done have been cosmetic.
I got mine for under $45k (at 5800 miles) and I'm convinced every day that I got a great deal. You'll be very happy with SPF.
MadMiles442
Old 02-07-2007, 10:46 PM
terry251's Avatar
Cobra Make, Engine: SPF Roadster, 418W
John, the early ones make nasty sounds around the knee area when they stand up, they take longer to eliminate in the middle of the night, and they sometimes forget stuff. Other than that...they are AWESOME. Also, the newer ones forget their manners sometimes.
All said and done? You can't go too far wrong!
Terry
Old 02-08-2007, 07:54 AM
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Terry,
Don't the older ones have more of a tendency to leak, too?
Lowell
Old 02-11-2007, 12:19 PM
Tom of VA's Avatar
Cobra Make, Engine: Superformance #095, w/ 1966 428
I have a very early car and have made many of the upgrades. Reinforcing the rear-end braket is no big deal. I am curious about the old windsheilds matching the new Shelbys. Does that mean the old body curves are closer to the original or new Shelby shape? Cutting the cross member sounds a little scary. How did your friend properly reinforce the frame boxes where he created a bolt-on cross member?
Old 02-11-2007, 01:11 PM
Rwillia4's Avatar
Default windshield
Isn't the windshield cracks indicative of frame twist? I have seen many SPF's that have a crack in the windshield and this is what steered me away. Has anything been done to make the frame stronger/stiffer.
Old 02-11-2007, 03:43 PM
Tom of VA's Avatar
I have never known of any problems with the frame or twisting on any year. Any windshield that has been broken was due to nomal things that break windshields. I only heard there was a inventory problem some years ago for the first generation shields.
PS:
Judging from the mounting places for the windshield and the looks of the structure I would say it was impossible to twist the car enough to distort that area.
How did you research this?
Old 02-11-2007, 03:46 PM
Cobrabill's Avatar
RWillia4-you made a bad decision based on really bad info.The SPF frame is one of the stronger frames on the market.My car is #126-no cracksThe windshield issue has NOTHING to do with the chassis.
Old 02-12-2007, 10:23 AM
greg schroeder's Avatar
my 2040 has a 3.73 gear in the Ford 8.8.
The new has a 3.46 gear is a Dana with stronger half shafts.
I'm happy with having a 3.73. I replaced my half shafts.
Old 02-12-2007, 11:19 AM
Cobra Make, Engine: Superformance 427SC - Ford 408ci Windsor
Send a message via AIM to czarsmith
"... Also, because he didn't want to take the interior apart to pull the tranny, I think mainly pulling the tunnel off, he had the tranny crossmember cut out so the tranny can be pulled from the bottom, and now the cross member is a bolt in. ..."
Cutting out the transmission crossmember and replacing it with a bolt in crossmember severly compromises the torsional strength of the frame. This modification is specifically NOT recommended by Superformance. The bolt in member cannot provide the same rigidity as the welded in original crossmember. If you want your frame to twist and flex this is a good way to accomplish that.
Herb Smith
Superformance #1062
408ci Windsor
Old 02-12-2007, 05:34 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
In the SCOF open-to-all section of the site, there is a paper called "Failure Resulting From Unauthorized Frame Modifications" This modification is a know no-no....
