Old 09-23-2007, 11:15 PM
Got the Bug's Avatar
Paul and Don,
Thanks again for the tips regarding the clutch resevoir! I bought the assembly form Summit and replaced it on Saturday.
I ended up cutting off about a 1/2" piece of the existing hose to ensure a that there was a good seal on the new resevoir. I snugged up the hose clamp and the new resevoir clamp (just using a screwdriver). I went out for a test run today...no more leak.
Doug
Old 09-02-2008, 05:22 PM
well, i have the same problem but need to know if its the slave or the master and where i can get a replacement part. Please see pics below:
Hope someone can define that for me..
Old 09-03-2008, 05:08 PM
Ibr8k4vetts's Avatar
slave
Mike Z
Old 09-03-2008, 05:49 PM
Peter - Your best bet is probably to pull the slave off and see if there's a PN that a parts store can cross reference for you. Looks pretty crusty and from your pictures, you can see the residue of the brake fluid.
Doug
Rate This Thread:
