Old 08-17-2007, 07:47 AM
Cobra Make, Engine: in the hunt ....
Default SPF owners
Folks, I have been looking for a used cobra for about a year now. I think I have found one that is right for me. It is a SPF # 18?? from 2005. It has the usual SPF options, and a 351W from Performance Enginering. This is a one owner car with abot 5,000 miles. It has not been wrecked, and looks to be taken well care of. I have asked the owner all questions I could think of, are there some standard questions I should ask? The only thing I have left to do is go see it in person. The car is blue with steel grey stripes, and is located in Cinn. I would really appreciate any advice.
Sean
Old 08-17-2007, 08:18 AM
I would question the car #18 from 2005. Last i recalled they were at car# in the #2000 range in 05.
Old 08-17-2007, 08:25 AM
JCoop's Avatar
I agree; be leary. I would think #18 would have been built in the mid to late 90s? Nothing wrong with having an early SPF, as long as the seller is forthcoming in providing correct build information.
Good luck.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 08-17-2007, 08:26 AM
Duplicate the car new for $52,900, you should be paying about 45k for that car with 5K miles
Old 08-17-2007, 08:41 AM
Cobra Make, Engine: SPF #1019
Guys, I think he means the car number is in the 1800's (ie: 18??), not #18.
Old 08-17-2007, 08:43 AM
jwoodard's Avatar
Question
I have car # 1938 from 2004 so I doubt an 18## car would be from 2005. It's possible I suppose, but I would suggest you verify that info. Also, some PE engines have been proven to not be built to specifications, so once again, do your due diligence.
Jim Woodard
Old 08-17-2007, 08:47 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
A #1800 series car could possibly be titled as a 2005 model, but most were 2004 models. Having the entire VIN# would be helpful. 2005's started around #1990. But remember, actual production date, time for transportation across the big pond, and the time spent in dealer inventory may effect the model year designation of the car. Major changes to the cars between car's #1800's and #1900 would be mainly the revision to the wiring harnesses. But the differences there are EXTREEMLY MINOR. Does Ohio title the car based on the year of the engine block maybe? Anyway, mechanically, there is little difference in the design of the car. Drop me an email if you have further questions along this line.
Old 08-17-2007, 08:52 AM
Banned
A new roller with anything short of a cheapo Ford crate engine and used Tremec (and YOU installing it) won't get close to your quote, Max. You still have local sales taxes, DMV fees, registration, etc. Any SPF done correctly will run in the high 50's to start.
You are correct on the used SPF with 5K for $45K...those deals can be found....during the dead of winter.
Sean, as far as the # of the car you're looking at, I think you're referring to #18xx, which may place it into '03-04 territory. Check the top flange on the headers (at the cylinder heads)...there is date stamp there (day/month/year) and that is somewhat of an indicator of the 'approximate' build time (my car, #747, has a date code of Feb 2000 as a reference, though it could have been built/assembled as early as Dec 1999).
Check the exterior paint really well. The finishes are awesome, but there have been some instances of bubbling and most owners had them warranty repaired (the dealer network stands behind their product quite well).
-Dean
Old 08-17-2007, 08:54 AM
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
Guys: I don't know if 2005 is that far off for a number 1800 car. -Easy to look up; just check with SPF. I have car 1245 and it was delivered in early 2002. I would guess most 1800 cars were delivered in '04.
nsurenceman- Is the car being sold by a private seller, or is it at Dynamic Motorsports (in Cinci)? I know Eric @ Performance Enginering and he is a top-notch builder that stands behind his stuff. Is the 351w in the car a custom built engine by PE or is it a Ford crate motor that they simply installed in the car?
Old 08-17-2007, 08:59 AM
wtm442's Avatar
Beam Me Up Scottie
BUY IT
and have fun. A reasonable price should be in the area of $48 to $50K during the summer, assuming it has no noticeable defects. Check the For Sale ads here on CC and Cobra Country for typical prices.
Warren
Old 08-17-2007, 09:12 AM
Cobra Make, Engine: SPF 545" stroked 460 - sold
SPF 1415 left Dynamic Reno as a roller on 06/18/2002 so I would estimate an 1800 number chassis would likely by a 2004 build. Would advise do a search here and on other similar forums for PE engine discussions and read back several years just for info, good luck on your decision
Old 08-17-2007, 12:32 PM
Guys, my mistake I checked my notes it is SPF# 1995 (2005). Thanks for all the replies. From what I've read here today, the price looks right. Again thanks for the help. The car is being sold by an individual that purchased it from the company mentioned above. P.E. did the engine install, a FMS crate engine. Dyno was around 400HP not RW, but plenty for my first endeavor.
Sean
Old 08-17-2007, 09:55 PM
Flyin_Freddie's Avatar
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Be afraid...be very, very afraid.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
Old 08-17-2007, 10:03 PM
Cobrabill's Avatar
Hey,Freddie-How are ya?
Old 08-18-2007, 11:29 PM
Hey, Billy...how's it hangin'...? Hope you're well ....
Flyin_Freddie
Old 08-19-2007, 03:57 PM
Sean: Hey, did you get your email?
Old 08-20-2007, 08:10 AM
Red,
You can call dynamic motorsports today and get what i referred to for 52900. PE 351 with 430 hp.
