Old 10-16-2007, 12:54 PM
Default SPF steering wheel..
Anyone had their steering wheel off?? Need to straighten my steering wheel as it has always been a tad crooked from day 1.... Don't want to booger it up so am looking for suggestions...does the steering wheel cap pop off or screw off?? I would assume it pops off as the diamond needs to be straight with the wheel also...
Thanks in advance...
Tom
Old 10-16-2007, 01:31 PM
Cobra Make, Engine: SPF 545" stroked 460 - sold
The cap just pops off - held in by a close fit and a rubber 0-ring - no rotation required
Old 10-16-2007, 01:39 PM
Cobra Make, Engine: Superformance, 434, Paxton blown
A credit card does a great job popping the emblem off.
Old 10-16-2007, 02:22 PM
yep, credit card or a plastic throw away knife will work too . Bill
Old 10-16-2007, 07:31 PM
Madmiles442's Avatar
Really easy to get the wheel off. After the cap's off, you'll see the nut. Loosen away. The wheel's on a grooved rod, just pull it off and over one groove.
I lined mine straight up-and-down and marked it with a Sharpie before removing it so I'd know where I started.
MadMiles442
Old 10-16-2007, 09:57 PM
Thanks to all!! Figured it was something like that just knew the answer was among the masses!! Thanks again!!
Tom
Old 10-17-2007, 09:50 PM
Cobra Make, Engine: Cardiac, 428 FE
You could also have an alignment shop put it up on the rack and have them adjust the tie rod ends to align the steering wheel to straight. Saves boogering up the screw heads on your wheel.
Paul
