Old 10-25-2007, 08:36 PM
Kenm4187's Avatar
Cobra Make, Engine: SPF# 2560
Default Broken Flywheel Teeth
I have a Roush 402R with a Tremec TKO600 trans. I have had it about 6-months and have about 1200 miles on it. The starter was making noises like it was not engaging properly. I replaced the starter and it made the same noise the first time, the second time I could here the starter but the motor would not turn. I pulled the starter and found about 3-inches of teeth were missing from the flywheel.
Have any of you had this happen? Do you know what caused it? Would they fix it under warranty?
Thanks,
Ken 2560
