Old 01-30-2008, 09:43 AM
boblyon1's Avatar
Cobra Make, Engine: SPF #633, 351w stroker, Tremec 3550
Default Help - Cooling System Problem
My SPF is #1399, made circa 1999, with about 6K on the engine. It has a Southern Automotive 351W & Tremec 5 speed. It always ran on the cool side, with the fans coming on rarely around 94 deg C. In colder weather it rarely got about 85 C, even when idleing. All of a sudden, on a cool-weather run with very little stop-and-go traffic, it overheated (without the fans coming on) and warped the head. I suspected that the thermostat (180 degree F I think) froze up. Well, now my mechanic has resurfaced the heads, put a cooler thermostat in (160 F) and it is still running up to 115 deg C with the fans coming on intermitantly, but not always when they should. Any ideas?
Bob
Bob
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
Old 01-30-2008, 09:57 AM
Cobra Make, Engine: ERA 427 SO
Maybe lower radiator hose collapsing (sucking shut) at cruise RPM, or water pump impeller came loose from the pump shaft?
Ken
Old 01-30-2008, 10:14 AM
Flyin_Freddie's Avatar
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
It could also be a bad - or at least misbehavin' - fan relay or the temp sensor. You should be able to see if the lower radiator hose is collapsing. I'd suspect the fan relay or temp sensor first. Both these have had some history of failure with the same symptoms you're reporting.
Also...you have SPF#1399....made in 1999? I beg to disagree. Mine is #770, and I have Q/A documents from the factory in Port Elizabeth dated June 2000. Mine is an Olthoff prepared car, that was delivered in October 2000. I suspect your car is a late 2001, if not a 2002 car.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
Old 01-30-2008, 10:24 AM
boblyon1's Avatar
Default Correction
My beast is SPF # 633 - what was I thinking. Thanks to both of you for your suggestions. Anyone else have an idea? -thanks.
Bob
Old 01-30-2008, 03:08 PM
The fans are controlled by the temp sensor in the radiator. I have changed mine twice since 1998. The temp sensor closes the relay coil starting the fans, I have replaced two of those since 1998. All seperate failures at four different times. I have since wired a manual switch to activate the fans incase either fails again. Sensor is in the radiator the relay is under the dash.
Good luck
Old 01-30-2008, 03:15 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
The new superformances now have a manual overide switch on the dash for the fans. I have 2742 with that switch. My old spf 0995 just had the temp controlled relay. I think superformance fianally figured it out. My two cents says change the relay and install a manual switch for backup.
Ed
Too close for missles, switching to guns.........
Old 01-30-2008, 04:03 PM
boblyon1's Avatar
Default Problem Solved ! Thanks
Thanks to everyone who gave input, especially mr0077 who nailed it. The water pump impeller was just spinning freely on the pum shaft.
Bob
Old 01-30-2008, 06:33 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Running a 160 in place of a 180 will not keep any car from over-heating. When the engine is producing heat faster than it is being taken away you overheat. This can be caused by too small a radiator, fans not running correctly, bad thermostats or in your case no (or low) coolant flow. The thermostat just regulates the temperature of the coolant in the water jacket. Your oil would prefer the 180.
Just my $0.02
Bob
Old 01-30-2008, 06:45 PM
Cobra Make, Engine: FFR, 302, Mas-Flo
I agree with Bob in Ct. The 160 degree thermostat is too cold. Put a 180 degree
stat back in. The way it is, the engine won't be able to get to normal operating
temperature and sluge will form in the oil due to condensation.
Old 01-30-2008, 07:51 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Use a balanced thermostat. It fails open. and be sure the little hole drilled on the edge is at the top when you install it. Be sure to purge all the air out of the system too. You can also get a lower temperature fan switch for the bottom of the radiator, but it's no fun to install...
Old 02-08-2008, 08:16 AM
Cobra Make, Engine: SPF #298 427 FI
I agree with the gremlins in the relay post. You can always try the manual switch route. Cheap, easy, and insurance in case further problems.
Old 09-15-2008, 02:30 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Default What do you think ?
Good luck
My fans (SPO 2811) come on around 85C and keep the engine cool...no problem, both work and suck air in...when I turn the engine off the fans will come on and then turn off when the water temp gets to below 80 except on a couple occasions when I have gone back out to the garage and they were running at 60C...on a couple occasions, they have ran the battery down ??? I have a manual switch on the dash...I guess my question is what is your guess, the temp sensor or the relay or what ??? If so, where do I get the parts ??.....to tell you the truth, I would just as soon do away with the automatic feature and just use the manual switch but I suppose, nothing is simple anymore ?? Thanks in advance for any advice...
Old 09-15-2008, 02:51 PM
FWB's Avatar
FWB FWB is offline
just for the insight....how many miles are on the water pump and what brand
is it?
Fred
Old 09-15-2008, 05:10 PM
boblyon1's Avatar
Fred - This problem surfaced about nine months ago and has been resolved for me. This thread has been essentially dead until revived today by Bartruff1 who has a related problem. I had about 8K miles on the car, engine from Southern Automotive. Goodluck Bartruff - You should get some good answers here.
Bob
