Old 03-14-2008, 06:03 AM
Default Wiper Fluid Reservoir Removal
I was thinking about pulling my wiper reservoir (don't plan on getting ANY use from it). Has anyone else done this? Does anything have to be done with the 2 wires connected to the wiper reservoir?
Old 03-14-2008, 06:12 AM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I removed mine. I can't remember it having two wires. If it did, I just unplugged them.
Scott
Old 03-14-2008, 07:22 AM
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
Mine's gone. Maybe things have changed since #237, but I had a manual vacuum pump - no wires.
Old 03-14-2008, 01:36 PM
65cobra1's Avatar
Cobra Make, Engine: SPF #2450, Roush 342RE
I removed mine, replaced the bolts back in the holes (For looks) then taped the wire ends and stuffed them back into their exit hole.
I did all that in case I ever want to re-install the washer system I won't have to look for all the parts or do any re-wiring.
Ivan
Forget the health food...I need all the preservatives I can get !!!
Old 03-14-2008, 03:25 PM
Cobra Make, Engine: SPF 2482 Shelby/Roush 427
I didn't remove mine as of yet, but did change the switch to run my fuel pump. Might just remove it now that I think about it. I did see one car with it hooked up and about 2/3 of the spray came right over the windshield. Pretty funny.
Old 03-14-2008, 04:18 PM
Banned
I removed mine so that I could locate my brake vacuum reservoir in a clean spot. Photos in gallery if curious. Never had a need for a windshield washer anyway, and don't use them unless it's raining and oil gets splashed up on the glass (the Cobra never sees water, so that's never a problem).
-Dean
Old 03-14-2008, 08:17 PM
Madmiles442's Avatar
I took mine out too. Just taped off the wires.
I took the wiper blades off too. Rain-X.
Those silly little blades just start flapping up in my line of sight at 120.
If I don't have any blades, I sure don't need no washer fluid!
MadMiles442
