Old 08-04-2008, 08:56 AM
Cobra Make, Engine: Superformance #2589 Titanium w/ Indigo Blue Stripes 408/351w TKO600
Default License Plate Bracket
Just finished my SPF build and plan on getting it titled this week. I was wondering what you guys use for your license plate brackets, not sure what would be "typical"?
Thanks for any info.
Old 08-04-2008, 09:15 AM
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
If you mean bracket, you can buy one here:
http://www.parts123.com/PartFrame.as...obra_Restorers
But, I'm guessing you mean frame. Here's a thread with some good information. It seems the distance between the bracket and the trunk latch on SPFs is not consistent.
license plate frame
Good luck with your new car!
Chuck
Old 08-04-2008, 09:27 AM
Got the Bug's Avatar
Richie18,
Congratulations on completing your build. Like Chuck said, the clearance between the bottom of the plate and trunk latch seems to vary. My car is 2613 and I've tried a couple of frames but nothing fits. Somebody mentioned that Autozone had a very small frame that might work, but the Autozone near me didn't have it. Others have taken a dremel tool and ground the frame to contour to the latch.
Doug
Old 08-04-2008, 10:44 AM
Cobra Make, Engine: 2001 SPF, Sold =(
Yep... my bracket clears by microns! I have some foam tape as backing to keep it from rubbing on the latch base.
Old 08-04-2008, 11:25 AM
vanoochka's Avatar
Wow, that's snug but at least you didn't have to grind.
Mine fits relative to the latch with room to spare. However, I twisted my bracket a teeny bit to increase the clearance between the plate and my paint. I have to pull the plate away from the trunk lid a little to twist the latch, but I don't open my trunk very often.
Didn't think of using foam, but will add a little as an extra measure - thanks for the tip.
Old 08-04-2008, 02:05 PM
Thanks a lot for the info guys. And yes i did mean frame.
Old 08-04-2008, 03:48 PM
I think those guys at Superformance need to measure the standard license plate size again. I tried the Shelby motors frame and I would have had to cut an inch off the bottom of the frame for it to fit. The one that Chuck (vanoochka) has came close, but would still require a bit of grinding to fit. I went to another Autozone today and they had an ultra thin chrome frame that might work (half as thin as Chuck's), but it had 4 holes and I only want two. Still searching....
Doug
Old 08-04-2008, 04:26 PM
vanoochka's Avatar
Doug,
Is the issue the height or depth of the frame? If it's height, do you have some room between the top of the frame and the bracket/light assembly? If so, could you grind out the top of the screw holes a little bit to move the frame/plate up and clear?
Just a thought.
Chuck
Old 08-04-2008, 07:07 PM
Dwight's Avatar
Smile Tag
I made one out of stainless and mounted a Finish Line "Shelby" bracket to it.
Dwight
the pictures are of the same Cobra taken the same day. Different yellow? No, same. It's a digital camera thing.
Old 08-04-2008, 07:47 PM
Wow, Chuck. That black frame really looks good against your black stripes. VERY clean looking.
Old 08-04-2008, 08:09 PM
vanoochka's Avatar
Thank you very much!
Old 08-05-2008, 04:55 AM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Default Why use a frame ???
I just put the plate on the back....and put the front plate (wa.) in the trunk. Haven't been stopped yet...
Old 08-05-2008, 05:09 AM
Just put two dummy screws and nuts in the bottom holes that match the top screws. It will look perfect. They are metric and get stainless steel
Old 10-12-2008, 06:33 PM
Based on a recommendation in a previous thread, I decided to give the Billet Specialties License Plate frame from JEGS a try.
http://www.jegs.com/i/Billet+Special...55020/10002/-1
The frame is thin and just clears the handle on 2613. If you wanted a little more clearance you could grind it to contour to the handle.
Doug
Old 10-13-2008, 04:53 PM
Richie,
I have Superformance 2259 and the plate bracket from Finishline did NOT fit. I ended up going to Tony Branda (cobranda.com) and getting one that fits like Powershifts. The price was only about $5-6 also. I agree that Superformace should increase the distance between the plate light and trunk handle.
Old 10-13-2008, 04:54 PM
Richie,
I have Superformance 2259 and the plate bracket from Finishline did NOT fit ( the Shelby Motors one). I ended up going to Tony Branda (cobranda.com) and getting one that fits like Powershifts. The price was only about $5-6 also. I agree that Superformace should increase the distance between the plate light and trunk handle.
