| 29 |
1Likes
08-05-2008, 06:03 AM
Cobra Make, Engine: Superformance #2589 Titanium w/ Indigo Blue Stripes 408/351w TKO600
My SPF (pics inside)
Got some pictures of my Superformance Cobra, Titanium w/ Indigo Blue stripes. #2589
The engine
It's a 351w stroked to 408 cubic inches, working with a TKO600. Probably expecting it to produce somewhere around 480-500hp. Plently for me.
Car is now running, just waiting to get certified in IL.
Just when I thought nothing could sound better than my 1969 Camaro with a 427, we started this thing up and it's amazing.  Hope to get a video up soon.
Lastly, any Cobra owners on the west side of IL, possibly on the IA/IL border or so, i'm located in the Quad Cities and have heard of a Cobra around here, just looking for anyone else out there.
08-05-2008, 06:14 AM
Beam Me Up Scottie
MA
Saweeeeet. Everthing so nice and new, with no dirt. Even the garage is almost spotless! A lift and a drain in your garage? Super nice!
Warren
08-05-2008, 07:07 AM
ny
Cobra Make, Engine: ERA # 208, 428CJ
Car is awesome!! Very clean setup !! Conratulations !!
08-05-2008, 07:33 AM
IA
Cobra Make, Engine: SPF 545" stroked 460 - sold
08-05-2008, 12:02 PM
Sweet car and garage. After 100 miles retorque the following;
1) half shaft bolts, if you find any loosen go back with loctite, a tell tale sign will be oil thrown on the under carriage.
2) drive shaft bolts
3) bellhousing to engine
4) bellhousing to transmission
5) driveshaft
08-05-2008, 12:15 PM
ny
Cobra Make, Engine: Gary Edwards Racing 460
I second the tightening post!! Drive shaft bolts are famous for coming loose. A little blue loctite usually does the trick.
Beautiful car! Enjoy.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
08-05-2008, 12:53 PM
Thanks for all of the comments, and i appreciate the info regarding tightening the bolts!
08-05-2008, 01:43 PM
One other item:
Inspect all your brake calipers and ensure the banjo and bleed screws are tight and not leaking.
I assume you know about the generic one's like motor mount bolts etc, steering linkage etc, assume nothing is tight. I also use a marker and mark the spinner relative to the center piece to make sure the spinners are not backing off. Needless to say once I am sure I am not taking the wheels off anymore then I will safety wire. Oh, make sure you grease your ball joints, upper and lower and the drive shaft has zerk fitting also.
08-05-2008, 02:24 PM
Cobra Make, Engine: Cutting Edge, Boss 429
Beautiful car! Great color combination.
08-05-2008, 02:28 PM
OK
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Gorgeous Cobra! Not a bad shop, either!
Congratulations and enjoy the "ride"!
Juggernaut
08-05-2008, 02:44 PM
UT
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
Great Pictures! What are all the knobs along the bottom of the dash? I know one is for wipers, one is for dash light dimmer, two are for cool air on each side. What are the other 2 for?
08-05-2008, 04:23 PM
Heater/defroster control & heater fan control.
STL Mark
08-05-2008, 04:28 PM
Who cares about the car, I wish I had a garage like that. Why does it seem like everyone has an immaculate shop in their home garage?
By the way, nice car too!
08-05-2008, 05:49 PM
Ne.
Very Nice !
What tires are on it ?
I've see that tread before, maybe Michelin pilots or Mickey Thompson ?
Kevin
08-05-2008, 06:12 PM
Very nice! Engine Factory 408?
08-05-2008, 07:38 PM
I'm thinkin that ain't at the house. Floor drain and in ground lift usually mean pro shop.
Nice lookin car and shop either way.
08-05-2008, 08:13 PM
Congratulations Richie18!! Is this a new motor or a new build? Just curious since I took delivery of my car just over a year ago and my chassis number is later.
Doug
08-06-2008, 06:43 AM
ny
Beautiful garage! looks like you will have to rig a new exhaust venting system
All you need now is a TV and the man cave is complete!
08-06-2008, 07:26 AM
Once again i appreciate all the comments, to answer all the questions...
Very Nice !
Goodyear F1 GS-D3, 305s in back.
Indeed it is.
This is a new build, i can only assume that this car has been sitting at the dealership for longer than others.
The TV is to the right, it's just not in the picture!
I know everyone loves pictures as do I, i'll take some more of the shop , the finished cobra, and show what else is lurking in there. Some hints to what else is in there
1) A coupe painted Le Mans Blue with white stripes packing a 427
2) A covertible, red with white coves packing a 283.
3) A mid engine car painted blue with an orange stripe
4) With side exhaust and over 500hp, its sound differs greatly from V8's.
Take a guess and Check back late tonight for more photos and the answer to these hints!
08-06-2008, 10:45 AM
Well, the red with white coves with a 283 means you have a Corvette from '57-'61.
