| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
11-18-2008, 07:23 PM
MO
Cobra Make, Engine: SPO 2715
Webers on your FE powered Superformance in here!
Guys, is there anyone here that owns a Superformance AND has an FE motor with Webers?
I am interested in your hood clearance, and air filter selection.
Eric
11-18-2008, 08:09 PM
AZ
Cobra Make, Engine: 65' SPF (511 CID) FE 427 Alum Block Shelby /Roush 600hp-625fpt sideoiler
I had to got to a 2" K&N filter. The 3" hit the hood. Clears by about 1/2". Check out my gallery. Works fine.
11-18-2008, 08:10 PM
Yup 428fe with stellings and k and n filter plenty of clearance
11-18-2008, 10:17 PM
Az
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
I could only hope for ANY air cleaner to fit the same engine in my CSX. No One seems to care about getting one to fit my car. I have seen several Fuel injected motors in a superformance with the K&N filters like spooky has.
11-19-2008, 08:19 AM
Banned
CA
11-19-2008, 07:03 PM
MO
I am guessing no one has webers (48 IDA's) on an FE in a Superformance.
I thought I'd have a rare car, but maybe a one of a kind...
E
11-19-2008, 07:34 PM
Il
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
Eric- I know 2 guys with Webers in a SPF, One is on a SB though, but the other is on a Shelby alum block 482. I'll see if I can contact the guy with the 482 and ask him to measure clearance and find out what filters he uses (I've never seen filters on it actually, just those little toppers with the holes!).
11-20-2008, 09:53 AM
MO
Thanks Terry!
That would be a help, for sure.
Eric
11-21-2008, 10:31 AM
Il
Eric- Well, I finally go an email back from the guy and he said....."Filters? You don't need no stinkin' filters!!!"
Like I said earlier, the only times I've seen his engine he simply has the alum tops (screens) on the stacks (with the holes). -Don't know what they're "official" name is called. He said that every time you go from the screens to filters you have to re-tune the engine and it's a PITA (which is why he doesn't change it).
And as for measuring clearance he said......."How do I measure the clearance? When the hood is closed, I can't get in there to measure! All I know is, the hood closes and doesn't rub when I'm driving. That's all I care about!"
-Sorry.........not much help.
11-21-2008, 10:36 AM
Playdoh is often used to measure hood clearance when it the hood is closed. You friend must not have any little kids running around the house.
11-21-2008, 10:43 AM
Il
No.....................he's just a smart a$$!
I was going to email him back with suggestions on how to measure, but I was afraid of the response I would get.
Instead, I sent him a message saying, "Thanks for all your help and advice.....a-hole!"
He sent me back a pic of a smiley face giving me the finger.
-It's just his way.
11-21-2008, 12:35 PM
MO
Terry,
Thanks for the effort (I really mean it  )
I am going to see what will work, as I would feel better about not sucking small rocks and bugs into my engine.
But at the end of the day I might have to run "naked".
E
11-21-2008, 06:37 PM
CA.
Cobra Make, Engine: Superformance, #930, 351W/427CID 419 RWHP (before the Webers!)
K&Ns on a 427 SB. SPF with the older non-raised hood. Tried them all--this was the best air cleaner I found!!
Terry Brown SPF #930 427W 419 RWHP 48 IDA Webers
"Remember, your car will not be more valuable after Track Day than it is the day before the event" - Eric W. instructional presentation on Track Day safety, 05/15/2008 WSCB
11-21-2008, 06:47 PM
NY
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Terry, Nice looking set-up!!
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
11-21-2008, 07:03 PM
MO
Terry,
Love your set-up, and it is what I am shooting for.
I might have trouble with the FE and hood clearance, so I ordered (2) filters like yours from RT, and two short 1" trumpets from DynaTek to try down at KCM.
I will be posting the results on my build thread.
Thanks again!
E
11-22-2008, 09:18 AM
CA.
To get the necessary hood clearance I had to go to a 1 1/2" tall velocity stack. ALSO, the stacks are 3 1/4" wide to get a tighter fit for the filters. No apparent difference in tuning. GOOD LUCK!
11-22-2008, 12:06 PM
MO
Terry,
The shorter stacks "should" lean out the system a bit, but I'll have to see.
Thanks again for the help!
E
11-28-2008, 11:54 AM
IL
Cobra Make, Engine: Titanium SPF, 521 CID Gessford.
If you are doing limited driving in the car, maybe you don't need filters. If it's a '500-1,000 miles per year' car, just run the Webers and screens. By the time dirt particulates entering the horns actually accumulate enough to force a rebuild, you'll be long dead.
Based on what I've seen, there are MANY engine components that will fail long before the dirt causes an issue, especially in a high HP side-oiler. This assumes you don't live down a 10 mile dusty country lane...
Join the N.R.A. -- Homeland Security begins in YOUR home.
12-01-2008, 04:24 AM
CA
We used to use an Empty Cigarette pack to measure hood clearance, of you could close the hood and not hear the cellophane crinkle --it was all good.
of course now that nobody smokes anymore , not sure what to use.
12-01-2008, 05:38 AM
MO
Oh they smoke, "they" are banned to smoke where no one sees or smells them.
We are still working on this issue, and I am hoping this will ultimatly be a helpful thread for others who want webers/FE motor/Superformance.
Thanks for the post!
E
