Old 12-08-2008, 12:06 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Default Door fit in SPF
Hello,
My driver door has a 2 mm sized chip of paint missing (fiberglass is ok) where the door meets (rubs?) the body near the windshield.
Is this normal? Can it be completely adjusted perfectly or this a traight of Cobras?
Old 12-08-2008, 06:36 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Take it back to the dealer. There should be no rubbing anywhere on an SPF. Everything should have been perfect from the factory and double checked by your dealer before you took delivery.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 12-08-2008, 07:25 AM
Absolutely not normal, take it back
Old 12-08-2008, 08:49 AM
Got the Bug's Avatar
You can try going back to the dealer. If the car was pre-owned, then the warranty wouldn't transfer. Also, I think the basic warranty on the car is 1 year.
Doug
Old 12-08-2008, 10:04 AM
Check the latching mechanism. A series of washers are mounted on a pin. Take one out and test for a better fit. If the rub results from a misaligned-door the problem is in the hinges and not easily remedied.
My SPF was delivered to my door with a passenger-side door that resisted opening and would not close. Obviously no one had tried it, from final assembly to delivery at Dynamic to final assembly by Performance Engineering. It was one of several delivery defects - including failing to realign the car after the engine and transmission were installed, shipping the car with a failed right rear seal that allowed grease to scatter the fender well, etc. - that became apparent in the 13,000 or so miles I put on the car before selling it, following repeated attempts at a thorough repair. In the end build quality proved disappointing.
A beautiful car, precisely assembled. Unfortunately I don't fit. Sold it after four hundred miles. Well, at least now I know a Cobra is not a car I can own.
Old 12-08-2008, 10:28 AM
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
My door gaps were uneven when the car was delivered. At the time, I noticed that other cars in the shipment had the same issue.
I was able to adjust the doors for a uniform door gap by loosening the hinge bolts and removing some adjustment washers from the latch pins, closing the doors and re-tightening the hinge bolts.
Old 12-08-2008, 10:32 AM
dont's Avatar
Cobra Make, Engine: SPF #1235
The doors are easy to adjust. Take the screws out that hole the map pocket to the door. Behind it their are 3 bolts that attach the hindge to the door. Close the door, loosen the 3 bolts and adjust the gaps as needed. Popsicle sticks work great as shims to get the gaps even.
Superformance #1235
460/T5
