			|  Main Menu |
			|  Nevada Classics |
			|  Advertise at CC |
			| S | M | T | W | T | F | S |
			|  |  |  | 1 | 2 | 3 | 4 |
| 5 | 6 | 7 | 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 | 16 | 17 | 18 |
| 19 | 20 | 21 | 22 | 23 | 24 | 25 |
| 26 | 27 | 28 | 29 | 30 | 31 |  |  |
			|  CC Advertisers |  |
				12-27-2008, 10:49 AM
			|  | Senior Club Cobra Member
						CA Cobra Make, Engine: SPF 2613 Titanium w/Black, Roush 402SR
	|    Not Ranked
				 Size of stock oil pressure gauge tube
 The compression fitting for my oil  gauge started leaking at the block yesterday.  The compression fitting on the block side doesn't look familiar to me, as I'm used to seeing a sleeve over the hose with a nut.
I'm running the stock nylon hose that came with the car.  Does anyone know if the oil  pressure hose and adapter ships stock with the SPF?  If so, what is the size of the stock nylon hose?
I plan to upgrade the oil  pressure gauge hose to a braided line, but at this point I wanted to get the car back together for a drive.
				__________________Doug
				12-27-2008, 01:13 PM
						Ca. Cobra Make, Engine: None, sold it
	|    Not Ranked
 All of the after market oil  pressure gauges that I have used have a 1/8 dia line. I don't know if it is ID or OD but if you go to a good auto parts store (Napa Auto Parts?) and tell them you need an 1/8" oil  line you should get what you need. Cut a small piece of the line off to compair it to. I used an electric sending unit ang gauge so I would not have oil  running into the interior of the car. Sometimes they leak.
Note: If you have enough slack line you can just cut off the end and reinstall it with a new ferrol (SP?)
Terry |
				12-27-2008, 02:14 PM
						CA Cobra Make, Engine: Superformance 460 SVO
	|    Not Ranked
 smiths gauges have a 1/8 bsp fitting on the back.  Nisonger has the kits on the web site. also Speedway parts has a braided line kit  http://www.speedwaymotors.com/braide...kits,4147.html . you will have to buy adapters to npt to bsp. I think Pegasus racing has the fittings |
				12-27-2008, 02:17 PM
	|    Not Ranked
 Here's a picture of the fitting that I took out of the block side.  The tube slides into the ferrule (marked with the line) which pushes into the adapter (2nd fitting from left).
Strange set up, since the ferrule isn't held in place by a cap nut.  The ferrule and hose always floated in the adapter piece, but never leaked.  A couple of spines on the ferrule are broken, so it's going to need to be replaced.
I know that the hose isn't 1/8" because I compared to the hose in a VDO replacement kit and the existing hose is larger.  Any ideas about what size the hose is and where I can find a replacement fitting?
				12-27-2008, 03:55 PM
						WV Cobra Make, Engine: SPF 2682, Roush 427
	|    Not Ranked
 Mine is stamped 3/16" |
				12-27-2008, 06:15 PM
			| CC Member
	|    Not Ranked
 Go to Oreily, or maybe autozone and buy the brass tubing kit.  It cost about $12.00 and will have the fittings, replace the nylon line with the brass line. |
				12-27-2008, 09:13 PM
						CA Cobra Make, Engine: Previous owner of SPF#1938, with a Keith Craft 496ci Genesis 427 side oiler, 667 FWHP, 633 FWTQ, 560 RWHP, 550 RWTQ.
	|    Not Ranked
 Suggest you call Hillbank and inquire.  They may have what you want in stock.
				__________________Jim Woodard
 Don't interfere with  somethin' that ain't botherin' you none.
				12-27-2008, 09:47 PM
	|    Not Ranked
 Thanks for the response guys.
					Originally Posted by CSCHWER  Mine is stamped 3/16" |  Guessing mine is 3/16" as well.  It's covered with some heat shield material right up to the block, so I was only able to cut off enough to take down to the local part store.
					Originally Posted by jwoodard  Suggest you call Hillbank and inquire.  They may have what you want in stock. |  I'll give Hillbank a call on Monday.  This is  probably what I'm looking for:
http://www.hillbankmotorsports.com/p...ucts_id=130192
Also found this...in Australia.   http://www.snakebite.com.au/smithsga...ech-p-292.html
				12-27-2008, 10:47 PM
			|  | CC Member
						ca Cobra Make, Engine: spf #1723 427w
	|    Not Ranked
 Doug call BAT or british american transfer as scott and I just replaced ours and they ship it complete with ends already on it. very easy to install!www.batinc.net
Greg
				__________________Greg spf 1723
				12-28-2008, 04:07 AM
			| CC Member
	|    Not Ranked
 Somewhere in the system, either a fitting with a rather small hole in it, or a long and small diameter piece of tubing will be installed.
The purpose is to protect the Bourdon tube in the gauge from the pulsations of the oil  pump.  Without that protection your gauge will not last any time at all. |
				12-28-2008, 09:08 AM
			|  | CC Member
						VA Cobra Make, Engine: Superformance Brock Coupe
	|    Not Ranked
 That push in connection you have is prone to failure - I know - been there. Go to napa with your measurements in hand. (the napa guy will try to convince you your line measurement has to be wrong - don't fall for it). Get a npt ferrule setup and be done with it. I spent more in gas than the actual part and accessing the area of replacement, tight quarters, is the hardest part -- Sharkey -- ex spf 734 & 1176 			 Last edited by shark; 12-28-2008 at 06:55 PM..
				01-09-2009, 04:26 PM
			| CC Member
						KS Cobra Make, Engine: Spf  Shelby alu block
	|    Not Ranked
 I used Dorman fittings 11B and 12B on my stock oil  line and it worked great.
Lyle |
				01-09-2009, 04:34 PM
			|  | Beam Me Up Scottie
					Join Date: Aug 2004 Location: Squantum (part of Quincy),
						MA Cobra Make, Engine: SPF1049  Titanium w/black stripes, 351W with Trick Flow Heads, Tremec 3550
	|    Not Ranked
 Get rid of the plastic tubing.  Only use metal.
				__________________Warren
				01-10-2009, 06:28 PM
			|  | CC Member
						CA Cobra Make, Engine: SPF_R_/BRG/FRBoss302/327CI/FordEFI/Under_Car_Exh/
	|    Not Ranked
 agreed. AN-3 braided hose is the only way to go.
 doug- i thought you ordered a line from batman.
				__________________Steve SPF 2734 MK3 / Brock Coupe #54- panavia.com
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -7. The time now is 12:13 AM.
