October 2025
26 27 28 29 30 31
Old 12-27-2008, 10:49 AM
Got the Bug's Avatar
Question Size of stock oil pressure gauge tube
The compression fitting for my oil gauge started leaking at the block yesterday. The compression fitting on the block side doesn't look familiar to me, as I'm used to seeing a sleeve over the hose with a nut.
I'm running the stock nylon hose that came with the car. Does anyone know if the oil pressure hose and adapter ships stock with the SPF? If so, what is the size of the stock nylon hose?
I plan to upgrade the oil pressure gauge hose to a braided line, but at this point I wanted to get the car back together for a drive.
Doug
Old 12-27-2008, 01:13 PM
All of the after market oil pressure gauges that I have used have a 1/8 dia line. I don't know if it is ID or OD but if you go to a good auto parts store (Napa Auto Parts?) and tell them you need an 1/8" oil line you should get what you need. Cut a small piece of the line off to compair it to. I used an electric sending unit ang gauge so I would not have oil running into the interior of the car. Sometimes they leak.
Note: If you have enough slack line you can just cut off the end and reinstall it with a new ferrol (SP?)
Terry
Old 12-27-2008, 02:14 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
smiths gauges have a 1/8 bsp fitting on the back. Nisonger has the kits on the web site. also Speedway parts has a braided line kit http://www.speedwaymotors.com/braide...kits,4147.html. you will have to buy adapters to npt to bsp. I think Pegasus racing has the fittings
Old 12-27-2008, 02:17 PM
Here's a picture of the fitting that I took out of the block side. The tube slides into the ferrule (marked with the line) which pushes into the adapter (2nd fitting from left).
Strange set up, since the ferrule isn't held in place by a cap nut. The ferrule and hose always floated in the adapter piece, but never leaked. A couple of spines on the ferrule are broken, so it's going to need to be replaced.
I know that the hose isn't 1/8" because I compared to the hose in a VDO replacement kit and the existing hose is larger. Any ideas about what size the hose is and where I can find a replacement fitting?
Doug
Old 12-27-2008, 03:55 PM
Cobra Make, Engine: SPF 2682, Roush 427
Mine is stamped 3/16"
Old 12-27-2008, 06:15 PM
Go to Oreily, or maybe autozone and buy the brass tubing kit. It cost about $12.00 and will have the fittings, replace the nylon line with the brass line.
Old 12-27-2008, 09:13 PM
jwoodard's Avatar
Suggest you call Hillbank and inquire. They may have what you want in stock.
Jim Woodard
Old 12-27-2008, 09:47 PM
Thanks for the response guys.
Guessing mine is 3/16" as well. It's covered with some heat shield material right up to the block, so I was only able to cut off enough to take down to the local part store.
I'll give Hillbank a call on Monday. This is probably what I'm looking for:
http://www.hillbankmotorsports.com/p...ucts_id=130192
Also found this...in Australia.
http://www.snakebite.com.au/smithsga...ech-p-292.html
Doug
Old 12-27-2008, 10:47 PM
Greg tripp's Avatar
Cobra Make, Engine: spf #1723 427w
Doug call BAT or british american transfer as scott and I just replaced ours and they ship it complete with ends already on it. very easy to install!
www.batinc.net
Greg
Greg spf 1723
Old 12-28-2008, 04:07 AM
Somewhere in the system, either a fitting with a rather small hole in it, or a long and small diameter piece of tubing will be installed.
The purpose is to protect the Bourdon tube in the gauge from the pulsations of the oil pump. Without that protection your gauge will not last any time at all.
Old 12-28-2008, 09:08 AM
shark's Avatar
Cobra Make, Engine: Superformance Brock Coupe
That push in connection you have is prone to failure - I know - been there. Go to napa with your measurements in hand. (the napa guy will try to convince you your line measurement has to be wrong - don't fall for it). Get a npt ferrule setup and be done with it. I spent more in gas than the actual part and accessing the area of replacement, tight quarters, is the hardest part -- Sharkey -- ex spf 734 & 1176
Old 01-09-2009, 04:26 PM
Cobra Make, Engine: Spf Shelby alu block
I used Dorman fittings 11B and 12B on my stock oil line and it worked great.
Lyle
Old 01-09-2009, 04:34 PM
wtm442's Avatar
Beam Me Up Scottie
Get rid of the plastic tubing. Only use metal.
Warren
Old 01-10-2009, 06:28 PM
PANAVIA's Avatar
agreed. AN-3 braided hose is the only way to go.
doug- i thought you ordered a line from batman.
