| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
03-13-2009, 02:33 AM
NZ
Cobra Make, Engine: Indigo Superformance MkIII. Ford 460, TKO600
HOT feet
Hi guys. I'm new. I have just finished SPF2828 and have been on the road only 2 months. It gets really hot in the drivers footwell, especially on long trips. Is that normal or can you do something about that?
For details on SPF2828 - click here
03-13-2009, 07:19 AM
ca
Cobra Make, Engine: superformance/427 fe ford
i am sure you have your footbox vent open ......................no? and yes they do get warm. check vents by blowing air through vent and check in footbox. might be an obstruction.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
03-13-2009, 11:33 AM
CA
I also lined the foot boxes with space blanket, and wrapped the first 12" of the header pipes , which dropped the temps significantly.
Steve
03-13-2009, 12:14 PM
wa
Steve
What did you wrap your header pipes with?
03-13-2009, 12:36 PM
Cobra Make, Engine: SPF#0760
By any chance are your headers getting overly hot too? (glowing?) Check the paint on the body where the header exits the bodywork...I have heard of having the timimg too far advanced an causing excessive heat in the headers. There is a stainless steel heat-shield with an air gap behind it to reflect heat from parts of the header and the footwell...might be worth taking a quick look at ...
SPFWiringDiagrams@Comcast.net
03-13-2009, 01:37 PM
CA
I've never really noticed a significant amount of heat in the footwell. On the hottest days, the air vent is ok as long as you don't mind hard air blowing on you.
Steve (Panavia) has under car exhaust, so he may be generating a bit more heat under his car.
Doug
03-13-2009, 11:29 PM
Beam Me Up Scottie
MA
1) Make sure the heater fan is OFF
2) Make sure the temp slide button is pushed all the way in against the dashboard
3) Close both heater "doors" under the dashboard
4) Open the fresh air vent.
The SPF heater is great, but only in the winter!
Warren
03-14-2009, 01:00 PM
CA
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
I have under body exhaust with the mufflers actually under the seats and I have no heat related issues at all.
03-15-2009, 02:39 PM
Zero issues here also, numerous times while driving in the "winter" 55F I would have to crank the heat up and then I would remember I left the vent open.
03-15-2009, 02:57 PM
ca
how is the car running? i mean rich or lean. if it's alittle on the lean side , pipes are going to be hotter than normal. thus creating a hotter footbox than normal.
03-15-2009, 03:51 PM
IL
Cobra Make, Engine: Titanium SPF, 521 CID Gessford.
I think we're talking about versus like a Corvette or something.
My footwells get pretty hot in the summer. Especially if I'm going slow.
And my fresh air vents blow 100 degree air in the summer. Do I need to turn the blower on to force in the cooler air? Does anyone have a way to cool these down?
Join the N.R.A. -- Homeland Security begins in YOUR home.
03-15-2009, 09:32 PM
Hey, tonkin if you can pull a piece of your carpet back, and see if it is insulated,under neath I would think being that it is a spf, that it would be very well insulated, and that means like dynomat, and another layer as well, if you dont have that then your sol.I would pull the carpet out and go from ther its not on the outer side.
03-17-2009, 12:16 AM
NZ
Hi Guys thanks for all the good advice. Have gone through all the suggestions and think I need to adjust the heat sheild and add more insulation under the carpets.
Thanks again...
