Old 04-06-2009, 06:43 PM
Default Throttle linkage
Hi all, was taking some parts off to send out for chrome, and wanted to take off the throttle linkage that is attatched to the fire wall, i already remove the other 2 arms but am having no luck on the one on the fire wall, is there some special way to remove it? i figured all i had to do was remove that small c clips at the one end and that it should slide out, but no luck, anyone know how to do remove it?
Old 04-07-2009, 06:46 AM
surley someone has done this before..... anyone know how to remove this?
Old 04-07-2009, 03:33 PM
someone??? anyone???
Old 04-07-2009, 03:56 PM
xlr8or's Avatar
Bueller?? Bueller??
Old 04-07-2009, 03:59 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Post a good photo...we'll get this answered 1-2-3...
SPFWiringDiagrams@Comcast.net
Old 04-08-2009, 06:11 PM
sorry blas for taking so long to post the pics...
but here they are
Old 04-08-2009, 08:30 PM
Blas's Avatar
If you look under the dash where the steering column exits through the firewall, at about the 10 o’clock position, you will see the head of a bolt, that's for the linkage bracket towards the drivers side...the other bolt...well lets just say, you got to really love chrome to get to that one...Just follow that same structural member towards the passenger side, first you'll see the two nuts and washers that hold on the clutch reservoir, keep looking to the right, the other bolt is there too...I think you'll need to remove the steering wheel to get into a position to reach that second nut...Maybe even need to remove the seat...unless you can bend like a pretzel. Knowing a "Little Person" from the Wizard of Oz would also be a solution...Good Luck.
Old 04-08-2009, 08:46 PM
Got the Bug's Avatar
Blas,
You're a diplomat. No judgment regarding the lengths one will go to chrome a part.
Like Dragnet....just the facts Blas, just the facts.
Doug
Old 04-08-2009, 11:59 PM
PANAVIA's Avatar
The heim joint eyelets on mine (2734) were made of a zincish metal that may not hold a chrome treatment that well.
You may want to spec a replacement heim joint / eyelet that is already shiny/chrome/polished.
this also may save you a $ or 2.
Old 04-09-2009, 01:31 AM
Silverback51's Avatar
How much HP will this add?
Old 04-09-2009, 04:33 AM
well they are saying it will add approx 75HP for the complete linkage.... hahaha what can i say i love the shiny stuff,
thanks Blas for your help on this one, i never thought i would have to remove the heim joints to get the linkage off.
anyone here have theirs chromed? any pics?
thanks guys for posting
Old 04-09-2009, 04:36 AM
Blas's Avatar
I thought you were planning to replace the Heim Joint pieces. I'm not sure how you would chrome that assembly and still keep it fuctional. I know chroming prices have gone sky high too. And you are correct in saying that it's probably cheaper to replace it. Someone here has already done this on CC, maybe search and find that person, and you have your source for parts. I'll look tonight to find him.
Old 04-09-2009, 04:58 AM
im not to worried about chroming the heim joint, i was just wanting to chrome the rod/shaft. i remember seeing a pic in someones gallery, but cant recall now who it was
Old 04-09-2009, 06:22 AM
Blas's Avatar
Thinking Back now, I believe they replaced the throttle linkage pieces with polished SS pieces not chromed original pieces.
Old 04-09-2009, 06:46 AM
75HP? I will have to look into this for mine.
Old 04-10-2009, 07:06 PM
hey blas. just wanted to say thanks, just took it off, wasnt to bad to get to the bolts
ill take pics of engine bay whe its all said and done
Old 04-10-2009, 07:11 PM
Blas's Avatar
I got pictures of the stainless swap.
Old 04-12-2009, 05:42 PM
Cobra Make, Engine: Superformance (Titanium & Black)
The pictures Blas has are from my car SPF#1004. I replaced every piece of linkage from the pedal to the carburetor with stainless steel. Everything came from www.mcmaster.com (Mcmaster-Carr)... stainless rod, flat bar to make the bell cranks, and the heim joints (Ball Joint Rod Ends on Page 1168), for the rod ends and to replace the two on the firewall holding the transverse rod in place. I had to have someone else TIG the bell cranks to the rods but otherwise all hand made and polished. I'll try to post pictures. I planned to start making them for other owners next winter but I had to delay my retirement for a year.
Old 04-22-2009, 06:52 PM
Blas's Avatar
And beautiful your install is to be sure...Thanks for sourcing the parts...It will be interesting to see the chromed version photos...
Old 04-22-2009, 09:52 PM
A couple pics of the linkage along with the stainless hood stops on the firewall, hood prop rod and bracket, even the clip that holds the prop rod in place (from stainless tubing). Now I'm in the middle of making new hood latches from stainless. Get the idea I hate cadmium plated parts?
