Old 07-16-2009, 12:53 PM
SunDude's Avatar
Default Tips for keeping those darn floormats in place?
I realize this is a bit tedious, but does anyone have a good tip for keeping my SPF floormats in place?
The darned things keep sliding around down there and get caught up under the pedals. Argh!
Am trying to avoid using anything adhesive, to keep the carpets looking good.
Old 07-16-2009, 01:30 PM
Cammer's Avatar
Cobra Make, Engine: ERA 427 SC - #463 - 427 SOHC
Default Floor mats.........
I got some of the lift-a-dot fasteners that are used to snap on the tonneau covers and put them through the floor and into the floor mats.........they snap in great!!!!
Shoot me an email and I can tell you where to get the hardware.
Dee Walters
Cammer
Dee Walters/Cammer
Austin Cobra Club
2008 TCC President
Old 07-16-2009, 01:35 PM
Karl Bebout's Avatar
After two very close calls caused by my floor mat getting tangled in the gas pedal, I used 3/8" polished carrige bolts and polished fender washers to bolt the darned things through the floor. Looks a little industrial, but not bad since I made sure the bolt heads are symetricaly placed. Have not had to worry about the mats moving ever since.
Karlos
Old 07-16-2009, 01:42 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
This is what I have found is simple and the mats haven't moved in two years.
http://http://www.ggbailey.com/webapp/wcs/stores/servlet/Product1_10151_10101_96084_-1_20051__Mat%20LocŪ%20Clips
Old 07-16-2009, 01:57 PM
SunDude's Avatar
Oooh, I like the look of these! I've dropped an email to GG Bailey customer service to enquire about shipping to Canada. Thanks for the tip.
Old 07-16-2009, 03:03 PM
Banned
Easy...
1. Punch a small hole in the rear corner of each floor mat.
2. Loop a medium length black nylon zip tie through each one, forming a small circle.
3. Loop another black nylon zip tie (this one a little longer) around the front mounting points of the seats, and thread this zip tie through the loops that you made at the floor mat.
4. Pull tight to the appropriate length and trim.
The black ties blend into the mats and carpeting and are hardly noticable.
-Dean
Old 07-16-2009, 03:19 PM
Silverback51's Avatar
I used sticky back velcro (the hook side) and they have not moved at all.
John Hall
Old 07-16-2009, 05:03 PM
1985 CCX's Avatar
I did what Cammer suggested. It is how they did it in the 60's.
SNG Barratt has them.........Cheap fix with correct look.
Old 07-16-2009, 05:51 PM
Dee Walters
Cammer
Maybe just post it here and share with the rest of us? Thanks!
Rodger
Old 07-16-2009, 06:14 PM
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
I only got these 1 year ago, but ditto.
Old 07-16-2009, 06:28 PM
I'm watching . I have carpet runner material for mats . they used to be held down by anti sub eye bolt and front of seat wedge. That material needs replacing and unsecured it has gotten in the way.
Mike H
Old 07-16-2009, 06:49 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Snaps, like used on canvas. 2 per mat looks like they are made to be there and they don't stick up.
Old 07-16-2009, 06:52 PM
ditto on the velcro........i even used to install my door panels and they have stayed put for 2 years...and no screws through the upholestry........
Old 07-17-2009, 10:50 AM
twobjshelbys's Avatar
Years ago my Mercedes had a very primitive (I thought, for them) method. It was a hook-shaped pin that doubled back onto itself and connected to the mat with a snap clip. You put the hook into the carpet. One per side and they never moved. I was looking on line for them myself.
Old 07-17-2009, 11:37 AM
ROUSHAC's Avatar
Ditto on the velcro.
Dave
Old 06-15-2010, 04:10 PM
Excellent thread (which I found with a simple search), great suggestions, another example of the value of this site. I just ordered the GG Bailey clips, sounds like that should solve my sliding floor mat problem.
Old 06-15-2010, 06:22 PM
Floor mats are merely for covering the wear spots in the carpet while the car is parked. Obviously, they need to be removed before take-off.
If your worried about the wear, glue a rubber pad down to the carpet (or better yet screw down a piece of aluminum plate). Then use the mat to cover the eye sore when parked.
Too much headache to just protect two square feet of carpet.
Old 06-15-2010, 06:54 PM
SunDude's Avatar
I've had the GG Bailey clips on my mats since last summer and they work great! A bit finnicky to get 'em placed just right, but after that they grip tightly. You'll be pleased with 'em.
Old 06-16-2010, 09:37 AM
The Mat-Loc clips are available on Amazon and since we get shipping for free I'm going to order a set. I think I only need one for each side.
Old 06-17-2010, 05:39 PM
Twobjshelbys, who is the we in "we get shipping for free," and in particular, does we include me? Larry Carlson
