Old 11-07-2009, 06:35 AM
Mooch's Avatar
Cobra Make, Engine: ERA 427 - #783
Post Maintenance Schedule
I'm putting together a maintenance list for my build and was looking for opinions/advice regarding what other people are doing on a regular basis.
Realize that people's opinions on intervals are never going to agree, so explain why you do it your way - not why someone else is an idiot for doing it their way. This is going to be a comprehensive list, so that it may seem WAY over done at one point and everything may not apply to you. Hopefully once this is rounded out everybody can refer to it, editing it for personal use.
Here's the list, and it will be edited as people's advice is added:
Every Fill Up/Every Start
Check engine oil
Check coolant level
Check tire pressures/spinners
500 Miles
Change engine oil and filter
1000 Miles
Check tightness of all chassis bolts
Adjust valve lash (solid lifters)
Every 3000 Miles
Check clutch/brake hydraulic fluid
Check engine drive belts for wear and tension
Adjust clutch play
Grease the lower spherical joint of the front shock
Every 6000 Miles
Inspect front brakes
Check timing
Check tires for wear
Alignment
Every 12,000 Miles
Check transmission fluid
Grease rear axle and driveshaft universal joints
Grease front upper and lower ball joints and outer tie rod ends
Inspect hoses and belts for wear
Change lifters
Every 24,000 Miles
Change PCV Valve
Every 24 months
Change coolant
Check rear brakes
Apply anti-seize to spinners
Every 3 years
Flush and replace brake fluid
Check valve lash (hydraulic lifters)
Clean/replace air filter
Change fuel filter
Mooch
ERA Registry Map
If you have an ERA and want to be listed, contact me with your info and I'll put it up. The minimum info I need is chassis number and location. The rest is up to you. The most information needed would be: chassis number, body type, city, name, CC nickname, and email address.
Old 11-07-2009, 06:57 AM
Mooch, are you opting for a solid cam? If you are going with a hydraulic you never need to check it -- especially on an FE if you run a bead of RTV around your VCs to keep leaks down. You should also check your coolant a little more often with a "no coolant recovery" system. Remember it's just spitting it out on the road, little bits at a time. Safety wire your spinners, but still remove them once a year or so and anti-seize them. Also, you should check for loose stuff every couple of months. A big FE rattles these cars like you wouldn't believe and everything that isn't safety-wired has a tendency to vibrate loose.
Old 11-07-2009, 07:14 AM
Mooch's Avatar
Turning towards a solid roller at this time, but haven't nailed it down yet. And no, I'm not doing a flat tappet...
I agree with your advise on anti-seizing the wing nuts - has been added. I had the "check the wing nuts" at every fill up since you are checking pressure at the same time and it takes half a sec so make sure your safety wire is intact.
Changed coolant check to with fill up.
Mooch
ERA Registry Map
Old 11-07-2009, 07:22 AM
Originally Posted by Mooch View Post
Turning towards a solid roller at this time...
OK, plenty of threads on solid roller cams and FEs, so I won't harp on it. Just make sure you understand it all and make an informed decision.
Old 11-07-2009, 07:33 AM
kayakjack's Avatar
Mooch,
You check trans fluid at 12,000 miles. How long between changes? I put GM Synthetic in my Tremec 3550 a while back. Expensive stuff, but I'd be glad to change it out from time to time if it will keep the trans happy.
Jack
Old 11-07-2009, 07:36 AM
Originally Posted by kayakjack View Post
Mooch,
If you're not tracking the car hard, your heirs should be tasked with the first Trans and Rear Differential fluid change.
Old 11-07-2009, 11:57 AM
Gunner's Avatar
Please, let's call them spinners. I make a firm practice of never paying attention to wingnuts, right or left handed.
Old 11-07-2009, 12:17 PM
Mooch's Avatar
spinners it is. wingnut.
Mooch
ERA Registry Map
Old 11-07-2009, 12:31 PM
He deserved that.
Old 11-07-2009, 06:53 PM
bobcowan's Avatar
Maintenance on most of these cars is really not that differant than any other car you won. Do you check the oil on your DD every time you fill the tank? Do you check tire pressure that often? Do you change the oil that often?
Unless you're really running it hard, or use a solid lifter cam, maintenance is pretty much the same as a Ford, Dodge, or Chevy with the same equipment.
Old 11-07-2009, 06:55 PM
Treat your leather seats with a good leather conditioner/protection every few months.
Old 11-07-2009, 07:40 PM
Gunner's Avatar
I haven't won any cars lately, but I'll assume you mean "own."
I'd have to qualify that statement by era. These cars have almost exactly the maintenance needs and schedule of any 1960s vehicle... which is vastly more demanding than most cars of the last twenty years.
We've had four new vehicles between us since 2000, and I've done less maintenance on all of them than in about any year of my older vehicles. There's almost no such thing as a tune-up, spark plugs last 100k, oil change intervals are in the 10-15k range, interior materials are far more durable, paint and finish need hardly anything besides washing. Brakes and wipers... that's about it.
I had to stop for a fuel filter for 707 this afternoon, since I have the rear wheels off, it's right there, and I don't think it's ever been changed in the three years/5500 miles of life. She commented that she thought a new car shouldn't need so much service... I just laughed.
Old 11-07-2009, 08:15 PM
RodKnock's Avatar
What about the wingnut on the air cleaner? Gotta check that wingnut. Wouldn't want that clanking around the engine compartment.
Old 11-07-2009, 09:28 PM
Default looose nuts
Oh, What about the loose nut behind the wheel?
Old 11-07-2009, 09:44 PM
Mooch's Avatar
or the two on the seat?
Line:
Me
Mooch
ERA Registry Map
Old 11-07-2009, 11:03 PM
Gunner's Avatar
He deserved that.
Well, I'd call them knockoffs but mine are REAL Halibrands...
Old 11-08-2009, 07:46 AM
bobcowan's Avatar
You're exactly right, and that's why I qualified it with, "the same as a Ford, Dodge, or Chevy with the same equipment."
If you use a good modern synthetic oil, why change it every 3K miles? If you use a new tire and wheel, why worry about the pressure so much? If you use a closed coolant recovery system, you won't loose any coolant.
Partly it depends on how you build it, and what parts and systems you use. And partly it depends on how you drive it. I'd bet most Cobra's would do perfectly well with changing the oil once a year.
Old 11-08-2009, 08:16 AM
Mooch's Avatar
Like I said it the beginning, intervals will never be agreed upon.
I do agree that many Cobras would be happy with a once a year oil change, but would I? I will admit that I change the synthetic oil in my daily driver every 10k miles. It is a modern engine made for daily use at moderate driving.
Just the engine I'm putting into my Cobra will cost about half of my daily driver. It will be driven hard and will be stressed every time it is driven. So I'm going to do frequent changes. Will it make any difference to the engine? It's debatable. Even if I know it makes no difference, I'll still do it. The placebo effect to my conscience is worth it.
To make it easier I'm doing some things.
1: Top-side oil changes with a Mityvac. The remote filter is easily accessible. It takes me ~10 minutes to do an oil change. Every third change will be traditional through the pan.
2: Rare earth magnets, pulled from old hard drives, on the remote oil filter. poor man's version of: http://www.shopfiltermag.com/ This should catch the bulk of small metal in the oil for when I do the top side changes, and the drain plug on the third change should get the rest.
Mooch
ERA Registry Map
