Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 06-17-2011, 12:29 PM
joyridin''s Avatar
Yes, but you would need new caliper adapters. Go here and check out what he has as far as packages.
North Racecars Brake Solutions
The calipers interchange for all rotor sizes, so you might want to go with a larger rotor diameter. I had the 11.65" rear rotors. Note that the hub diameter on the disk brake axles is larger than the drum brake axles. So to really make this correct, you would need the caliper brackets for a disk brake rear, and Fox axles with the SN95 hub and 5 lug. This would allow the rear rotors to fit without the need for a sleeve over the center hub.
When I built my CMC, I had the rear axle narrowed. It can be shortened about 2.25" per side and retain the factory lower control arm mounting. I used Curry axles that were 2.25" shorter than Fox length with the SN95 5 lug and center hub. I used Forte adapters with a 11.65" diameter rotor.
Don't forget...if you go with rear disk, you would also need the master cylinder for that set-up.
Display Modes
HTML code is On
