Old 02-24-2012, 10:23 AM
Cobra Make, Engine: AC Autokraft AK1085 302 4V
Question Jaguar Rear Caliper Rebuild Advice
I am helping out a friend get his early Contemporary Classic 427SC back on the road. The brakes are the last item that need doing. The early XKE inboard rear calipers are both frozen up. Where would I get them rebuilt or buy replacements?
Old 02-24-2012, 12:05 PM
Cobra Make, Engine: Scratch-built 427 MR
Apple Hydraulics in Calverton,N.Y. can rebuild them. Also, I used a Wilwood caliper on mine. You need to make a simple bracket to install them. (My rear end is out of a 3.8S and the brakes on this one are a little different from some of the early E-types.) The calipers were Dynapro 120-9687. Only cost about $105 each.I will try to load a picture for you. Bill.
Old 02-24-2012, 02:35 PM
joyridin''s Avatar
I'm curious to see the picture also. How did you handle the e-brake?
Old 02-24-2012, 03:08 PM
I had to use a line-lock from Speedway. Put in the line with my Prop valve on the left side.
Old 02-24-2012, 07:00 PM
mickmate's Avatar
Welsh Enterprises - New Jaguar Parts, Used Jaguar Parts and Accessories - XK120 - XK140 - XK150 - E-Type - MK - XJ6 - XJ8 - XJ - XK8 - XK - XJS - S-Type - X-Type - XF
SNG Barratt - USA | Parts | Brake Caliper LHR
mickmate
http://www.actoncustom.com/
Old 02-25-2012, 05:57 AM
joyridin''s Avatar
Thanks for the info. Were you able to get a picture uploaded? I wouldn't mind removing the old Jag calipers off my car. They work fine, but they are a pain in the tight area.
Old 02-25-2012, 04:30 PM
Cobra Make, Engine: Shelby, 1964 CSX2367, fully restored, I'm the second owner, SAAC Div 1 Premiere 2003&2012
Default Jaguar rear caliper rebuild
The original Dunlop calipers work fine once they are rebuilt. My wife and I have put many miles on various Etypes over the years. Much more than the Cobra anyway. I've settled on having calipers resleeved to standard size with stainless steel by Apple or Whie Post. They can supply new pistons if needed. Then be sure to bleed at least annually to keep moisture out.
That said, newer calipers like wildwood and vented grooved discs are a good upgrade. Dave
Dave Wathen
1964 CSX2367
1938 Jaguar SS100
1953 XK120 roadster
1966 Etype roadster
1971 280SE 3.5 Cabriolet
