Old 04-22-2013, 10:24 AM
1985 CCX's Avatar
Default Jaguar Differential - Pinion Yoke
Guys
Looking for a pinion yoke for a Jag Diffy................ Want to sell one?
Second, What is the measurment from the base of the yoke where it attaches to the diffy to the center of the U-Joint?
Old 04-22-2013, 12:19 PM
joyridin''s Avatar
What spline count do you need? I have a couple for original Jag gears.
Old 04-22-2013, 03:50 PM
mickmate's Avatar
Hey Jeff I think you need the flange yoke as in the back end of the drive shaft??
mickmate
http://www.actoncustom.com/
Old 04-22-2013, 03:52 PM
1985 CCX's Avatar
Sorry guys Flange Yoke........... Driveshaft connection............
What part # do you know............
Old 04-22-2013, 10:08 PM
Coventry West has those in stock most of the time.
Old 04-23-2013, 12:50 PM
1985 CCX's Avatar
No luck
Old 04-23-2013, 01:10 PM
i have some here in the uk if you want to pay the postage.
Old 04-23-2013, 01:28 PM
Tom Wells's Avatar
Still confused (actually I stay that way...); is this what you're looking for: 1310 Series Flange Yoke for Jaguar Dana 44 Rear Differential
Or might it be the topmost piece in this diagram:
Tom
Old 04-23-2013, 03:14 PM
SSSammy's Avatar
Default Spicer 2-2-459 1310 Flange Yoke
Tom, you have pictured the mating part, called a pinion flange. Your URL leads to a generic flange yoke that will probably work.
I bought mine per the ERA Manual, and they specify the Spicer branded part as it is proven, strength-wise. See:
Or google: "Spicer 2-2-459" ... lot's of sources. I can testify that it is good for 614 ft-lbs TQ The stub axles will break first ... don't ask
The OP also needs the specific bolts and locking nuts, if he does not have them.
The dims are here:
http://www2.dana.com/pdf/J300-P2.pdf
Sam
Old 04-23-2013, 03:23 PM
1985 CCX's Avatar
Thanks guys.........................
Old 06-19-2013, 03:30 AM
Eljaro's Avatar
is it this what you need?
http://s1141.photobucket.com/user/lo...lange.jpg.html
have one.
Old 06-19-2013, 06:43 AM
1985 CCX's Avatar
I needed the flange yoke....
Thank you all for the help, now we are all set
Bottom of page:
289 progress........
