Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Like Tree1Likes
  • 1 Post By Texasdoc
Old 09-07-2016, 08:19 PM
bjretired's Avatar
Cobra Make, Engine: Antique Collectable, Chevy BB
Default EZ wiring nightmare
I'm in the process of re wiring my AC & C with an EZ harness (mice attacked). I am also changing out the steering column to a Stainless tilt wheel with GM wiring. the EZ instructions are a tad vauge.......I can figure out most of it but the brake lights. Orange hot wire to the fuse then orange wire to bl switch then thecolumn harness P terminal white wire to the other side of the switch. the brake lights are supposed to work with the turn signals? Before I just ran a hot wire to the bl switch them back to the lights. Is the a real diagram on how the gm steering (wiring works)? EZ doesn't have a electrical book for dummy's do they? Thanks bob
Pics americantorque.com/bj
Old 09-08-2016, 05:19 AM
Texasdoc's Avatar
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Sounds similar to the painless wiring harness. You can download their manual HERE and see if it is the same.
Basically the power goes from the fuse box to the brake sensor, to the column. The internal guts of the column determine when to add power to either both lights (brake only) or to flash one (turn signal on). The column output wires should be labeled depending on where they go. It depends if you are having both lights on each side flash as one or having one be brake only and the other only work as a flash/turn signal.
Painless's diagram isn't great but hopefully you can see how it is supposed to be done. The magic of low light (parking indicators), high light (brakes), or flashing happens inside the column circuitry.
White wire comes in from the brake switch.
Purple wire provides 12v+ flashed power to the column.
Yellow and Green are output wires to the brake lights.
If the white wire is hot (brake pedal is pressed), both "brake" wires get 12v+
If the turn signal switch is pushed up or down, the one brake light is flashed - purple wire signal (flashed) is passed to the brake light on the side selected so that light flashes.
If both the brake is pressed and the turn signal is engaged, the flashed signal is passed to the correct side (turn/flashing) and the white wire signal is passed to the other side (brake/constant).
The front lights are easier since they aren't pulling multiple duties.
bjretired likes this.
Old 09-08-2016, 07:18 AM
bjretired's Avatar
Default Lights
Thanks that explains a lot. Bob
Display Modes
HTML code is On
