Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 04-20-2017, 09:48 AM
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
Default Shift Light info needed.
Im searching for a compact shift light for the column and have found numerous makes but many have bad reviews. I want one that does not require the RPM activated switch which is an additional purchase and more complex install. So far I like the MSD 89631 all in one unit but need your input for those that have a shift light before I buy one. Which model do you have or like? Pros and cons. Thanks
Your ride should not be to get from point to point. It should BE the point!
Old 04-21-2017, 05:48 PM
FWB's Avatar
FWB FWB is offline
i use the MSD 8952, small uses a pill i can change quickly, i have it mounted to the column also
Fred B
Old 04-23-2017, 09:44 AM
Good info here and thanks for the reply. The MSD 89631 smaller version I really like too. No pills but is programmed for the RPM right on the top of unit.
Old 05-03-2019, 03:33 AM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
How will you mount the MSD 89631? Pic if already mounted please.
The Omex Shift Light Pro ( https://www.merlinmotorsport.co.uk/p...ight-pro-omslp ) might be the smallest, most discreet one I have seen. The small single 10mm round LED light can be incorporated in the dash to resemble a normal warning light...
Old 05-04-2019, 04:13 AM
Cobra Make, Engine: VMS BDR - 5.0 Aluminator - Whipplecharged
I have a shift light mounted on the steering column. Works great.
Old 05-04-2019, 12:33 PM
What about a sequential shift light system.
Here's an example:
Digital Race Electronics Sequential Shift Light System
Measure 2.3" x .63" x 1.38".
Small enough it could easily be fitted anywhere without a bracket.
Use 7/8" 3M Attachment Tape (double sided auto molding tape).
High adhesion but removable without leaving bonding marks.
HTML code is On
