Old 10-10-2021, 06:36 PM
Cobra Make, Engine: Everett Morrison FE 428
Default Aluminum calipers
Does anyone know of an OEM aluminum caliper with parking brake? Has anyone used an electric E brake caliper?
Old 10-10-2021, 06:58 PM
t walgamuth's Avatar
There is a floating caliper which is steel but comes with a cable operated parking function. It does not weigh much more than a caliper wo the ebrake. GM
Old 10-10-2021, 08:10 PM
jknich's Avatar
89-92 Camaro/Firebird.
https://www.rockauto.com/en/moreinfo...=1704&jsn=1089
Jim Nichols
Old 10-11-2021, 03:39 PM
cycleguy55's Avatar
4-piston main calipers. Electronic parking brake.
https://www.wilwood.com/BrakeKits/Br...o=140-16142-DR
Wilwood also has mechanical parking brakes: https://www.wilwood.com/Calipers/Cal...4%20Mechanical
Brian
Old 10-12-2021, 10:05 AM
Those Camaros are what Iam looking for but the pistons are too small. Thanks
Old 10-13-2021, 10:03 AM
cycleguy55's Avatar
Speedmaster has an aluminum caliper setup with integral parking brake. Single 1.75" piston. Fits 11" rotors (not included). Fits Ford 9" rear end with "small ends" (Torino). I have no idea whether that's what you have, but you should be able to figure it out with a few measurements.
https://www.speedmaster79.com/BRAKE-CALIPERS
Speedmaster also offers a "Ford Late Model Large & Small Bearing 4 Piston 12" Rear Brake Kit". Aluminum calipers and mechanical drum parking brakes. Drilled and slotted rotors.
https://www.speedmaster79.com/Ford-L...Rear-Brake-Kit
Brian
Tags
aluminum rear caliper, oem caliper
