Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
December 2025
Like Tree4Likes
  • 1 Post By Docket
  • 1 Post By patrickt
  • 1 Post By Docket
  • 1 Post By xb-60
Old 07-24-2023, 07:19 PM
Default Loose Shifter Bolts MKIV AK2003
The shifter on my car was loose and it was the two bolts that secured the handle to the base on the transmission. The way AC built the car the boot was riveted to the trans tunnel from the bottom. The only way to access the bolts is to pull the seats, remove the seat belt mechanisms, the seat belt anchors and the ten sheetmetal screws that secure the tunnel to the floor. Put the shifter in 1st, 3rd or reverse and the tunnel will come forward and off. Tighten the two screws on the handle and reverse the procedure. You need an 11MM socket for the seats which is a nut that you don't see very often.
1985 CCX likes this.
HTML code is On
