  #41 (permalink)
Old 02-24-2004, 10:27 AM
No I didn't know I needed to bench bleed. This could be my problem.
Roger
  #42 (permalink)
Old 02-24-2004, 10:30 AM
rdorman's Avatar
Renegade Nuns on Wheels
It is a good standatd practice to get into. It will help show problems before they become hard to find and it will make bleeding the system a simpler process.
OhioCobraClub.com
LondonCobraShow.com
  #43 (permalink)
Old 02-25-2004, 05:59 PM
Success!!!!
I now have brakes in good working order.
Thanks guys for all of your help.
Happy Motoring
Roger
  #44 (permalink)
Old 02-25-2004, 06:00 PM
rdorman's Avatar
You can't get off that easy Roger! What did you do?
OhioCobraClub.com
LondonCobraShow.com
  #45 (permalink)
Old 02-25-2004, 06:46 PM
We removed the cylinder for the front brakes, inspected it and did not find a problem.
When reassembled the system we unscrewed the clevis ( the brass fitting that the balance bar threads through ) a few turns so we could get more pedal throw. We then bleed the front and back brakes ( on side at a time as mentioned in this thread ).
I suspect we were not getting enough pedal throw to get all of the air out of the system.
It will be warm enough to drive tomorrow so I will give the brakes a try on the open road ( tonights tests were just in the driveway)
I'm glad to have this problem behind me!
Next step is to install the soft top and heater.
Thanks again
Roger
  #46 (permalink)
Old 02-26-2004, 05:18 AM
rdorman's Avatar
So the piston in the master cylinders where not fully returning when the pedal was released?
OhioCobraClub.com
LondonCobraShow.com
  #47 (permalink)
Old 10-13-2021, 09:21 PM
Cobra Make, Engine: Replica Motor Company
In a conventional car the master cylinders sit high on the firewall and brake bleeding is not a problem and it can be done with one person using a brake bleeding tool.
Tiltons/Wilwood or others underfloor pedal system it is the reverse, The master cylinder bottles are mounted at floor level making the process is difficult.Sure- follow Tiltons Direction and the trick is that the bottles should be mounted high enough or raise the vehicle so as the M/C are higher than your calipers to facilitate bleeding.
