| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
07-31-2002, 07:48 PM
IL
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Books on Small Block Fords...
I NEED to learn more about SB Fords before I get one...Help me start a library. I have learned a lot from you guys but it isn't enough. I have
"Ford Windsor Small-Block Performance: Parts and Modifications for High Performance Street and Racing
by Isaac Martin"
"Ford Performance
by Pat Ganahl"
on my list do I need any more?
GS
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
07-31-2002, 07:55 PM
NY
2 goodies
How to Rebuild Small-Block Ford Engines
by Tom Monroe
High Performance Ford Engine Parts Interchange (S-A Design)
by George Reid
07-31-2002, 07:58 PM
Usually one big staple is: "How to Rebuild Small-Block Ford Engines" by Tom Monroe
Good facts in there too, like the boss 302 came with a 2.23" valve.
That's huge.
Sorta ends at the early 80's tho. 5.0 blocks aren't covered.
-steve in nj-
"I wanted to meet interesting and stimulating people of an ancient culture and, kill them."
CO
Cobra Make, Engine: Midstates, 460
Books
I have:
"Ford V8 Engines" by Tom Monroe
"How to Build Max Performance Ford V8s on a Budget" by George Reid
"High Performance Small Block Ford Engines" by Hot Rod Magazine.
So far I am not impressed with the Hot Rod one because the engines in it are not very streetable (it seems, I am still reading though). I am still reading all of them, which realy gets confusing  . I just bought them the other day, so I haven't had a chance to read very far into any of them yet.
Hope this helps,
Bran
"Clowns to the left of me,
Jokers to the right..."
Brandon
07-31-2002, 08:23 PM
IL
cool...Thanks guys. I'm gonna order them tommorow and hopefully some folks put in their input. BTW Brandon I emailed OZ and the told me the Off Set is 45 positive?
GS
N.D.N.P.N.P.
08-01-2002, 07:40 PM
IL
Any other books?
GS
N.D.N.P.N.P.
08-01-2002, 08:13 PM
What may also be important is what you plan on doing with this motor that you eventually build.
Street? Strip? Roadrace?
Carb? EFI?
-steve in nj-
The Tom Monroe book I mentioned earlier is a good repair and replace book. Detailed on how to teardown and rebuild an engine. It even has a chapter on how to remove an engine from a vehicle.
08-01-2002, 08:16 PM
IL
Gonna get a 351w built by Engine Factory...Or a 392 crate or a 396 from EF. All will be carbed and setup for street/strip.
GS
N.D.N.P.N.P.
08-04-2002, 04:57 PM
Seasoned Member
VA
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
GS;
Check out "Building Ford Short-Track Power" from Ford Racing. Also "How to Build Horsepower" Vol. I and Vol II by David Vizard. (Not Ford or small-block specific but good reading) Also "1001 High Performance Tips" by Wayne Scraba for all around good common sensical (?) pointers on building and racing. Good luck with your build.
Bill Stradtner
HTML code is On
