Old 08-28-2002, 12:41 PM
rdorman's Avatar
Renegade Nuns on Wheels
Default pedistal mounted rocker on 351C adjustment
Just to be sure, after all it has been a long time. The non-adjustable pedistal mounted rockers on a 351 Cleveland, just torque them down right? No backing off, no making sure the valves are closed, etc?
Some one please confirm!
Old 08-28-2002, 02:13 PM
I will check when I get home.The book I used when I built my cleveland I wont to say it tells you to turn the crank so that there is minimum pressure on the rockers.
I will let you.
Bill
Old 08-29-2002, 06:45 AM
Rick if you have a fax # I will make a copy of what I have.the adjustment is made depends on the type of rocker arms your engine has.
This infomation is out of the (How to Rebuild FORD V8 ENGINES) by Tom Monroe
Regards
Bill
