Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 09-18-2002, 08:04 AM
Default Residual pressure valve?
Anyboby are used Wilwood 2lbs residual pressure valve for disc brake with master cylinder fitted below calipers.Any improvment?
Thanks for reply
Bernie
Bernie 289 FIA
Old 11-08-2002, 07:08 AM
427 S/O's Avatar
Yes, I installed wilwoods new
'compact master cylinders' below the foot box and it was necessary to use their 2lb residual valves. I did a little
preventative maintenance after about 1000mi and wondered if the break pads might be difficult to remove?, no problem, you can push the pistons with your fingers!.
Perry
Display Modes
HTML code is On
