Old 10-28-2002, 11:48 PM
Default Edelbrock heads on 302 windsor
Hi guys,
I've got a Windsor 302 in my Cobra and would like to put some aftermarket heads on.
If I put on a set of Edelbrock heads on, are the exhaust ports in exactly the same position as the standard heads? My headers have been made for my (very tight) engine bay and I really don't want to have to change them.
Simon
At over $6 per gallon, we must REALLY love our cars in the UK !
Old 10-29-2002, 12:02 AM
Exactly tha same
Bernie
Bernie 289 FIA
Old 10-29-2002, 12:04 AM
Default 302 heads
Bernie,
Simon
Old 10-29-2002, 01:35 AM
lot of mustang guys out here are getting the new AFR heads, suppose to be better
Old 11-07-2002, 12:34 PM
How much do the Victor Junior heads differ from the standard exhaust port height and bolt spacing, I have been considering replacing my Trickflows with these and am looking at the pro's and cons.
Andy
Promoting 289's in a country awash with 427's
Old 11-07-2002, 12:42 PM
SSSnake's Avatar
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
World Products heads also have the stock exhaust port location.
Glenn
Old 11-07-2002, 04:10 PM
All of the street replacement heads have the intake, and exhaust manifolds (& headers) using the same bolt patterns and gaskets. The higher up the curve you go toward a track or racing head, the more the manufacturers take liberties with moving things like exhaust ports and bolt patterns around to optimize flow.
So the FMS Sportsman, TFS-R, and the like, will need a new set of headers. Roush Iron heads, Ede Performer RPM, AFR 165 - 185, TFS Twisted Wedge Street need no exhaust modifications.
If your TFS heads have the 2.02/1.60 valves, see no advantage to replacing with Ede's. You may even loose some HP.
