Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 04-03-2003, 07:12 PM
Cobra Make, Engine: 2003 Ford Cobra Mustang
Send a message via ICQ to LateApex Send a message via AIM to LateApex
Default Starter or battery?
Guys, my GT349.5 running a 289 has a unique problem. My guess is it's the starter. If the car is cold, the starter will crank the daylights out of the (high compression motor) once it gets a few initial turns in. If I run the car, it's warm, and try to restart it in ten minutes, it ain't pretty. I run a bunch of Webers, and in a downhill hard on the brakes stopping for a light session, the motor will stall (lack of fuel pressure--I know, I know I need to deal with that) and when it's time to relight the motor, the starter says, time for a siesta. It'll attempt cranking, but not enough grunt to close the deal. If I let the car sit, and try in 20 minutes, no problem. 2 hours, even better, fires right up.
I am thinking starter has gotten old dealing with this motor. I have made sure battery is fully charged. THERE are no other weak battery symptoms, but battery is certainly 3 years old. I usually run 'em till they can't take a charge.
What do you think?? Sorry this is not a pure Cobra question, as I have no Cobra right now.
no signature
Old 04-03-2003, 07:27 PM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
Well, if the starter works fine cold, then the problem isn't the starter (by itself). Sounds like heat soak. Might be something as simple as too small of cable between the battery and solenoid or solenoid and starter ... or even a poor ground line.
Or it could be that the starter itself is being heat soaked (I seem to remember that Chevy V8s have this problem). A heat shield between the starter and headers might cure the problem.
Just a guess...
Pete K.
Who is John Galt?
Old 04-03-2003, 07:48 PM
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
yes on the above.
Most likely bad, dirty connections or weak ground. When it start OK cold, basics, etc working. When hot, thinks have expanded and changed contact loads/points, connection forces etc and you pick up some high impedience somewhere.
gn
Old 04-03-2003, 07:50 PM
Dwight's Avatar
CHECK INTO A HIGH TORQUE MINI STARTER. COACH MIKE AND I HAD THE SAME PROBLEM. INSTALLED THE MINI STARTERS AND NO HOT START PROBLEMS. BUT FIRST CHECK THE GROUND CONNECTION AND CABLE SIZE. GROUND THE MOTOR TO THE FRAME WITH A GOOD CABLE. HEAT SHIELD DID NOT WORK FOR US. LOCAL HOME TOWN PART STORE HAD THE STARTERS FOR A $130 EXCHANGE.
Old 04-03-2003, 07:55 PM
KobraKarl's Avatar
maybe check your timing for a little too much advance
Foolish consistancy is the hobgoblin of tiny minds
Old 04-03-2003, 08:52 PM
Junket's Avatar
Cobra Make, Engine: shell valley
I would pull the starter and take it to a parts house to be tested belive that it is tired enough with the high compression and the expanding gases in the motor when it hot it could be a little vaper locked.
Ken
Talent is your head in communication with your balls.
Old 04-05-2003, 11:19 AM
Send a message via AIM to cobrakit66
positive cable, check for corrosion inside of the insulation
ron
cobrakit66
Old 04-06-2003, 04:14 AM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Thumbs up
Had the same problem. Wouldn't start when hot like the battery had gone flat. My ground cable went from the battery to the frame and then to the block. This cable was a bit on the light side. I ran a new and much heavier cable from the battery direct to the block, problem solved.
Regards,
Bryan
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 04-20-2003, 07:19 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Default Hot Start
Had the same problem. Tried all the above. Backed off the timing abit, no more problem.
Jim
Old 04-20-2003, 09:25 PM
If your running headers and they are close to the starter than you may need a heat shield over the starter. This is a common problem and very frequently on late 60's and early 70's chevys. As for the chevy problem they work great new, give a little time and they won't work hot. Install an aluminum heat shield and the problem goes away.
ac289cobra
Old 04-20-2003, 09:35 PM
I experienced the the same problem with my 427FE. My battery is in the trunk. I had a ground wire going to the frame under the battery. I relocated it to the scattershield. I also got 0 guage wiring and I got a good, new battery. (Interstate). Now, it always starts when hot, but does strain a bit. Now its time to back off on the timing.
Good luck.
Old 05-12-2003, 04:34 AM
68gt500's Avatar
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Send a message via Yahoo to 68gt500
Next time you have that condition
Disable the ignition and try again:
If it will crank ok ->too much timing advance
Won´t crank ok -> check connections and then get a new starter !
Old 05-12-2003, 05:17 AM
Cobra Make, Engine: KMP/427co
Send a message via AIM to shaps Send a message via MSN to shaps
Had similar experience on sb chevy with hdrs. Solved it with mini-starter along with a heat shield. Best of luck!
Old 05-12-2003, 06:38 AM
Roscoe's Avatar
My MSD Digital 6 ignition has a 20 degree start retard built in. Depending on your ignition setup you may be able to buy a separate start retard for your engine which might help your situation. Prevents hard starting and kickback.
Roscoe
Roscoe
HTML code is On
