Old 06-03-2003, 04:24 PM
Default Rim Backspace question
ok, If the rearend has clearance for 5.5 backspace what does that measurement represent. Also if it is 5.5 is it safe to go to a 5 or 4.5?
Old 06-03-2003, 05:59 PM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Yup, you can use less backspacing, but the downside is that your tires will be sticking out past the body.
Nonconformist. Can't handle a real job.
Old 06-03-2003, 06:02 PM
If you use more what happens? Like 6 or 7?
Old 06-03-2003, 06:17 PM
Slow Dawg's Avatar
The backside of your tires will rub on the frame and fiberglass above the frame.
Old 06-03-2003, 06:19 PM
Dawg, are their any factory rearends that would allow a larger rim size that is stock? I see people using a lincoln rear?
Old 06-03-2003, 06:22 PM
something that is bigger than 8 inch rim. Bryan mentioned to me 8.8 ford the largest rim that could be used is an 8 inch with 5.5 backspace. hard to find rims that size.
Old 06-03-2003, 06:41 PM
Slow Dawg's Avatar
The only factory rears that we used were the Lincoln Mark VII (8.8") and the Lincoln Versailles (9"). The 9" is a little narrower than the 8.8. Now we only use a narrowed 9" shortened by Moser with new Moser axles shafts. You could use a 10" wide rim, but there's just not much room between the frame and the outside of the fenderwell, so your tire may be sticking out past the body just a little. It's not too late to order one of those narrowed axles from Karen. Oh well, since I'm trying to spend your money, have Karen toss in the tubular front with the Carrera shocks also.
Old 06-03-2003, 06:49 PM
Ron are you bryan's partner their? Just putting 2 and 2 together, and buy the way I told bryan yesterday to go ahead with the full tubular front end. I think I might be calling again in a couple days to just add the rearend as well. The price is great for all new stuff and no headaches.
Old 06-03-2003, 06:51 PM
With the shortened rearend what size rims could I run then? 10's no problem?
Old 06-03-2003, 07:37 PM
Slow Dawg's Avatar
Nope! Barry is Bryans partner. But I've been there 5 1/2 years. Doesn't feel like a day over 20! Te he he he. Next time you call, ask Bryan what size and backspacing he has on his silver car. Those are just right. I can't remember what they are.
Old 06-03-2003, 07:41 PM
Thanks Ron, Make sure that frame thats going to Mass. gets good welds and extra paint.. Hehe
