Old 11-06-2003, 05:37 PM
Default hydralic slave
I've a Shell Valley cobra with the clutch & brake pedals mounted to the frame.The guy I got it from said the master and slave cly. are from a 62 Chevy truck.I'm in the process of hopping up the engine and changing to a T-5.The trans. that was in the car is a SROD 4-speed and the clutch took appox. 75 lbs. of foot pressure to disengage.(no joke). Since I have to make a new bracket to mount the slave cly. to the gearbox I was wondering if there is a better master-slave cyl. combo that would be less stressful to my left leg-foot combo.
Old 11-07-2003, 04:54 PM
try johnsmustangs.com
Old 11-07-2003, 06:22 PM
Back in Black's Avatar
Default Contact Tilton
They make the best slave units, bar none !
http://www.tiltonracing.com/
Old 11-10-2003, 09:05 AM
Original Shelby Owner
Any major auto parts store, such as NAPA, can sell you a unit that works on Ford bellhousings for around $35.00. Check EIS or Raybestos.
Old 11-11-2003, 04:27 PM
Being that the tranny is being changed out, you might check out the McCleod HTOB (hydraulic thow-out bearing). It eliminates the need for a slave cylinder. No fork is needed. It is pretty expensive but worth it. All it is, is a line that goes from the master cylinder to inside the bell housing and pushes a piston that travels the throw-out bearing. Very easy to install.
Butler Racing Inc. 058
Old 11-12-2003, 07:06 AM
For those contemplating using a internal hydraulic TOB, you may want to do a search on CC regarding the pros and cons. This topic has come up on a number of occasions and the responses of people using them is worth the search.
Old 11-19-2003, 07:13 AM
The Raybetos Slave Cylinder number is SC 33721
Old 11-19-2003, 07:54 AM
Default JMC Slave Setup
Hey Mike,
Team-C-Racing is a distributor of JMC parts I can get you a slave setup for a T5..or Tremec if needed..drop me an email with your zipcode and I can give you a price with shipping..... info@teamcracing.com
Brian
www.teamcracing.com
