Old 09-01-2004, 03:07 PM
Cobra Make, Engine: Venom 427 351W 425h.p.
Unhappy Ceramic coated Headers/sidepipes
For anyone having the slip on Header/Sidepipe set up. If you are having them ceramic coated make sure that you have the sidepipe "expanded" first! Thats right I did not and they would not fit after I had them done(duh), sooooooooo I sanded, ground, etc but could only get them on part way. I took the sidepipes to our local muffler shop to have them expanded. (believe me I did not sleep real well thinking of all that could go wrong) Luckily nothing
happened.............but I would highly recommend doing it first.
Old 09-01-2004, 06:57 PM
Rick Parker's Avatar
Your point is well taken. I'm sure it is dependent upon the initial clearances of the fit, in my application they fit OK after coating without any tweaking, other than fighting to get each individual pipe into the collector in turn. I finally machined a spacer to mimic the thickness of the center of the collector, then inserted it into the center of the four pipes, then put a LARGE hose clamp around them and slipped the collector and sidepipe assembly onto the primary pipes.
http://www.clubcobra.com/photopost/d...re_190__2_.jpg
American Industrial Coatings
7637 Fair Oaks Blvd
Carmichael, Ca 95608
916 944-3300
Old 09-01-2004, 10:23 PM
Cobra Make, Engine: Superformance 351W
4U2NV,
How much did that run? For both $$$
GWC
Old 09-01-2004, 10:29 PM
Turk's Avatar
Send a message via Yahoo to Turk
Do they coat the inside of the pipes? Is that why they wouldn't fit?
OBAMA IN in 2012
Old 09-01-2004, 10:36 PM
Yes they normally will attempt to coat them inside and out.
They shy away from attempting to do inside the mufflers however.
Old 09-02-2004, 08:12 AM
Gee Double, I believe it was about - +$600.00 for the coating (JET HOT) lowers temperature under the hood about 100 degrees gives 1-3% more HP..... to have them expanded after was $20.00 ( went back a second time for one side )
Old 09-02-2004, 05:36 PM
Don Don is offline
Default Finish Line Coatings
The company mentioned in the Sept/Oct Kit Car Builder, page 28 & 29:
Lona Jenson
Russ Meeks
R & M Engineering/Finish Line
2889 SE Silversprings Rd
Milwaukie OR 97222
503.659.4278
www.finishlinecoatings.com
For the ceramic coating on the side pipes, price quoted was $350 + shipping
Old 09-07-2004, 01:56 PM
Cobra Make, Engine: SPF / 514 Stroker
Send a message via Yahoo to Karl Muller
Default Ceramic Coating
Does anyone know where to have sidepipes coated in the Philadelphia, New Jersey, Delaware or Maryland area?
I prefer not to ship them....
Old 09-07-2004, 02:12 PM
Don Don is offline
Default Air Born Coatings
Air Born Coatings is in East Hartford CT.
www.airborncoatings.com
Price, do not know if it is current, for Corvette/Cobra Headers and Sidepipes was/is $375
ERA and FFR might ( ? ) have their work done by Air Born. ERA is located 15 miles away.
Old 09-22-2006, 07:28 PM
Default Sidepipes
Don't use Embee in Santa Ana CA...they coat very thin, and used C-clamps to hang onto my sidepipes...leaving nice rosettes all over them.
scratch
