Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-12-2005, 12:29 PM
Cobra Make, Engine: Several
We switched to 1.7's on a stock FORD 385hp 351W Crate and it seriously brightened up the engine. No dyno #'s, but i would guess 15-20hp. A few thousand miles or so and they are just fine. Same springs, no stacking. i've got nice 2 into 2 headers, so that helps also.
Not sure about the cam/spring/piston clearance on a newer 392 FORD stroker 351.
To be cautious, i index the plug tang to the top (or between the valves) position and limit it to 35thou, even though the MSD will fire 40 (or 50) with ease. i shift hard at 6500-6600, quite regularly. Nice motor.
Nice mod, but with a bigger cam lift, who knows? Better measure, if not stock. Same with revised springs. The 750 Holley HP certainly likes to feed the deeper opening valves.
Got the trick from a 'Stang Drager.
Works fine for me.
"A free people ought not only to be armed and disciplined but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government."
George Washington
Display Modes
HTML code is On
