Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 10-24-2006, 05:03 PM
Default For exhaust that works awesome
I sent this to Eric at Chassic Chambered exhaust. I thought this might be of interest to others as well.
Hello Eric,
We put the mufflers on yesterday and Holly crap!!!, what a difference I gained a hundred 100hp & 100 Fpt easy. I used to have to use the clutch to get my tires to spin, Not no more, I just tap the gas, and the tires are a blazing even at 30 miles an hour, Just touch the gas and your going sideways. I still can't believe what it has done to my car even Gord said If he hadn't seen it with his own eyes he wouldn't believe it. Its like Nitrous. I ran them in both directions they sounded better in backwards, a nicer deeper sound, and they weren't much louder. We tested them in side the shop with a Db meter, It was a more controlled environment. Readings with stock mufflers were 98 Db @ 2000rpm 110Db @ 3000rpm 106Db @ 4000rpm With the power stix in the right way readings were 103Db @ 2000rpm 108Db @3000rpm 111 @4000rpm with them in backwards they were they were 106Db @ 2000rpm 107Db @ 3000rpm 109Db @ 4000rpm. You have to remember we were inside a shop, When we moved it outside it was a lot quieter.also my idle went up 175 rpm just from better flow. Again thank you I only wish I would have changed the mufflers before I changed my engine It mostly likely had enough power in the first motor .
Thanks again,
Grant Steele
Old 10-24-2006, 05:27 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Grant,
Was this their CobraPack mufflers?? 4" outside diameter?
Thanks
Dave
55 mph is unsafe at any speed. Huh?
Old 10-24-2006, 05:47 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Grant,
Were they packed or unpacked?
Brad
Old 10-24-2006, 07:27 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Hmmm, what car, SPF ? What engine?
" It ain't no big deal"
Old 10-25-2006, 09:57 AM
Cobra Make, Engine: SPF832, 466cid
All cobrapacks are 4" OD...I would want to know length, packed/unpacked, and ID.
Curtis
Old 10-25-2006, 10:06 AM
ROUSHAC's Avatar
This should answer some questions:
http://www.classicchambered.com/clas...cts.html#cobra
Prices:
https://www.security-order.com/class...red/index.html
Cheers!
Dave
Dave
Old 10-25-2006, 10:31 AM
Thumbs up
I have a set of cobrapacks 20" length,4 dia body and 3" center now all i need to do is get a car to put them on. I paid $62.00 ea plus shipping to calif.the classicchambered web site has a sound bit of a 498 bb with 26 mufflers it sounds great.
Old 10-25-2006, 05:10 PM
I think most have the link....The question is what is it ExcessiveHP is using?
POWER STIX or COBRAPACKS and what are the dimentions. He mentioned power stix so that ends the "Cobrapack" question.
thanks,
curtis
The 20" x 3" "Cobrapacks" packed or unpacked looks real gooood!
Old 10-27-2006, 05:53 PM
Rare Iron's Avatar
Grant (the poster) ordered & installed 32" bodied Cobrapacks (not crimped Powersticks) with NO packing, & 2.5" cores. His neighbor Gord ordered the same mufflers, but with 36" bodies. They ordered 2.5" cores for a little more sound control - 3" would have been louder & they were afraid of too loud. 2.5" flowpath = HUGE improvement in flow vs. the stock mufflers. WAAAAAY more cfm through 2.5" vs. 2" or smaller. Fear not, the small louvers DO NOT hurt the flow very much, & they are necessary for better sound attenuation.
Thanks, -Eric
CCEI
Old 10-27-2006, 08:54 PM
Eric, Good info.....Thanks.
curtis
Old 10-27-2006, 09:19 PM
Okay so I am a bit new to this, how do they go into my existing side pipes? Would I have to get the re ceramic coated?
Dan
Old 10-28-2006, 06:51 AM
Burgs's Avatar
Dan, No they don't, and yes you will. The existing muffler section would be cut off, and the new one would be welded on, then re coated. I'm curious what size the Hurricane pipes are on the inside.
Brad
Old 11-04-2006, 06:02 PM
Rare Iron's Avatar
Brad
Anybody know the flow path size of the Hurricane pipes? If they are relatively quiet, I'll guarantee they are a 2" or smaller flow path.
Old 11-04-2006, 07:22 PM
Burgs's Avatar
Eric,
I should be able to answer the Hurricane flow path size question tomorrow.
I have assumed the Cobrapack and the Powerstick are different in design internally,... is that correct?
Brad
Old 11-05-2006, 09:22 AM
Burgs's Avatar
I have one of the early cars, #6, and the best I can tell, it's 2", and feels like it has the louvers like your cobra packs. I believe they are packed with glass, because when I started the car for the first time, there was what appeared to be airborne glass fibers floating around. As you say, I think they are relatively quiet.
Old 11-05-2006, 05:24 PM
Rare Iron's Avatar
Eric,
Brad
Same design louver core & same diameters as with the 2.5" & 3" Powersticks. The Cobrapacks have smooth bodies, so there are no dimples to create sound wave irregularities (or tuning). Also, the larger diameter bodies of the Cobrapacks allow for a larger gap between the core & outer body, which will permit more dissipation of sound. The larger gap also allows for loading of sound deadening materials as an option. Packed mufflers will flow the same as ones without packing.
Old 11-05-2006, 06:12 PM
Burgs's Avatar
Doesn't the "sound wave irregularities, (or tuning)" give them a unique sound, different from the Cobrapacks?
Old 11-05-2006, 06:43 PM
Rare Iron's Avatar
Yep, but you guys want smooth bodies. Kinetic used the crimped Powerstics & roll-formed a smooth skin to cover the dimples, & tack welded the "skin" on the inbord so you couldn't see the seam. Reports are though that the smoothies also sound very good.
Old 11-05-2006, 07:19 PM
Burgs's Avatar
I had the GMMG chambered exhaust system on an '02 SS Camaro with long tube headers, and loved the sound. I was thinking of using the side pipe inserts, but I see now the length may be an issue.
Old 11-05-2006, 07:39 PM
Cobra Make, Engine: Unique Motorcars 289 FIA, S. Automotive 354 stroker
Ordered at set of 26" 2.5" cores, packed last week. Can't wait to get them in. Going to dyno and retune the car after install, so you guys will have another data point.
Ran an 11.98 with the current setup today. Hoping the new exhaust keeps me solid in the 11's.
HTML code is On
