| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
04-10-2007, 05:51 AM
CT
Cobra Make, Engine: ERA 289 FIA. 302 Edelbrock heads
Valve Cover Breather
I'm a new owner of a ERA 289 FIA and love it. But, it's blowing oil out the valve cover breathers (slowly). Do I need to attach the breather to the intake system? It's a 302 about 325-340 hp. Any help would be appreciated.
Thanks
04-10-2007, 06:23 AM
Ca
Welcome to the site.
Do you have breathers on each cover? Try putting a piece of fuel cell foam in each one. It works! I have found that a piece about 2"-2 1/2" diameter X 2" long will stay secure in the vent tube without any help.
Rick
04-10-2007, 06:35 AM
NC
Or you could mount a remote breather and puke tank... solves the problem and looks great.
James
Charlotte, NC
04-10-2007, 07:10 AM
Beam Me Up Scottie
MA
Are there baffles inside the valve covers? The baffles prevent oil being splashed onto the fittings by the rocker arms. One valve cover should be attached to the vacuum fitting (usually 3/8 " dia) at the base of the carb. The other valve cover should have a breather.
Warren
04-10-2007, 07:14 AM
Member of the north
Cobra Make, Engine: A Cobra
Rick, does that get saturated and start to drip?
I tried something simular and after an hour of high RPM driving, I found my breather was dripping. If this works, I will thank you now.
Warren, you may have to add baffles. I made mine out of Stanless and chromed acorn nuts through the covers.
04-10-2007, 07:20 AM
Beam Me Up Scottie
MA
Tru
I have baffles in both valve covers (Ford Motorsports). No drips on my Cobra.
I'm sorry to hear that your breather is dripping! Maybe some Viagra will help.
Warren
04-10-2007, 08:44 AM
Member of the north
Warren,
I heard some of those low RPM engines do not have this problem. Good to hear you are not.
Possibly if the application of the "rib" made a lick of sense, I could find humor in it.
However, should you find yourself with this problem...there is no cure for syphilis.
04-10-2007, 08:52 AM
MA
Cobra Make, Engine: ERA FIA #2039
Valve cober breathers
Rick Parker,
See, you could sell another set of your covers !!!
Pat
04-10-2007, 08:53 AM
NC
Originally Posted by wtm442
Tru
If you are taking Viagra for a drip, you need to check the certificate on the wall at your doctors office and see if he went to school in Peurto Rico... Usually they perscribe antibiotics.. ask me how I know...
James
Charlotte, NC
04-10-2007, 06:07 PM
CT
I have breathers in both covers and no baffles. Where can I find the fuel cell foam? Any ideas.
Rob
04-10-2007, 06:44 PM
Ca
Trularin: No it does not get saturated to the point that it drips. What actually happens is that the oil vapors that are usually pumped up and into the breather are fliltered and "air" without the oil is what gets up to the breather. In my setup I have no slash shields and have used the fuel cell foam in 2 different sets of covers with equal success. One set had the set up like GT 350R with one breather per cover, my current setup uses 2 breather tubes in each cover (FIA type) ( Gallery pictures of each available).
Robspiceman: Fuel cell foam is available from most Circle track vendors or Fuel Cell manufacturers (isn't ATL in your general area?) Replace it about once a year or when you think of it.
This works very well guys.
Rick
04-11-2007, 10:17 AM
Club Cobra Member
NJ
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Try the cleaning isle at the local food store. Look for a Stainless scouring pad. Cut a piece off and shove it into the breather tube.
 Snakebit
04-11-2007, 07:21 PM
Seasoned Member
VA
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Green Scotchbrite works too.
Bill Stradtner
HTML code is On
