Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 07-25-2007, 11:40 AM
63mercury's Avatar
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
Default IRS help
I have access to the IRS unit from an 89 Cougar with the 1.0 in dia axles my question is; is there a way to upgrade this unit to the 1.2 dia axle and spider gear or should I just look for the unit with the 1.2 Dia axles? Another question, will this unit(the 1.0 in) handle the power of a 250 hp 5.0 sbf ?
Thanks Carl.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
Old 07-25-2007, 08:19 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
I believe the unit with 1" axles is not a 8.8 but a 7 something not worth much. You should be able to find one easily just look for a model with a V8 and rear disk. Heck there are three at my You-Pull hangout right now. 8.8 is cast right in the pumkin for easy reference. Patrick
Old 07-26-2007, 09:32 AM
63mercury's Avatar
Thanks Patrick, I read that the 8.8 came both ways the one I found has something cast into the top but with the dirt and lack of room its hard to tell while its still in the car, I think the lookin will continue. Thanks again Carl.
Old 08-10-2007, 05:33 AM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
You need to look for a TBird SC or a Cougar XR7. Those two have the correct components, including the axles. Other models may have the track lock and disc brakes, but those two have for sure. The auto equipped cars normally used a 3.27 ratio, and the manual cars normally used a 3.08. The 3.27 can be used as is, but I would recommend changing out the 3.08 to something a little more sporting. John
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
HTML code is On
