Old 10-08-2007, 09:35 AM
Cobra Make, Engine: Backdraft cobra, Ford motorsports 302, holly carb
Default Carburetor Leaking
I smelled gas under the hood and when i checked the back of the carburetor was leaking enough to pool in the manifold. I pulled the carb, checked the rear float bowl and gasket and didn't see any obvious cracks or breaks in the gasket. I cleaned it up, put it back and it is doing the same thing. It seems like it might be leaking around the feed tube - there is the brass fitting in the carb and then the stainless connector going into it. Both are tight.
I remember in the old days (20 years ago) using teflon tape on fuel connections. Is that still appropriate? or is this likely something else. I have a feeling something else is the problem, mostly due to the quantity of fuel leaking.
Can the float bowls be replaced (in case it's a crack) or do i have to get a new carb?
Any suggestions or other things to look for would be greatly appreciated.
Old 10-08-2007, 09:47 AM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
check out Summitt Racing, check out the link below. have never heard of one cracking
http://store.summitracing.com/egnsea...=KeywordSearch
Old 10-08-2007, 10:02 AM
Banned
Check the o-rings on the float bowl bolts and the feed tube. Doesn't take much for those to go. Eliminate the obvious first.
-Dean
Old 10-08-2007, 04:23 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
I had a leak on the back of my Holley too. if you have a double pumper, check the diapham. mine were hard and cracked. replaced in ten minutes and hasn't leaked yet.
