Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 10-05-2008, 05:36 PM
Default Rear Wheel Bearings -Removal
Shelby 427 Cobra CSX 4000 Series with Spicer Half Shafts in the rear. Unable to remove the outer wheel bearing (1 of 2) from shaft. Have removed the roller bearing cage and the bearings, now all that remains on the shaft is the inner bearing race. A LOT of heat has been applied plus prying, twisting and pressing. Have not been able to get even the slightest movement. It seems as if it's galled onto the shaft.
Any suggestions would be appreciated!
HTML code is On
