Old 10-23-2008, 10:04 AM
kitcarbp's Avatar
Default Air Cleaner Size Calculator
I want to thank the Second Strike.com newsletter for taking the guess work out in estimating the appropriate size of an air cleaner. Has anyone else used this calculator? Has anyone used a flow bench to validate the model ? Would be neat to see the correlation.
Since I dont have access to a flow bench, this is helpful. Are there other models out there ? Comments?
http://www.secondstrike.com/Technica...leanerCalc.asp
Old 10-23-2008, 12:42 PM
Hotfingrs's Avatar
I don't put much stock in that calculator. It says I'm losing 23.3 horsepower, yet on a chassis dyno, I gain 11 horse and 8 lbs of torque, with my air cleaner versus NO air cleaner.
Jack
XSSIVE .....
Old 10-23-2008, 02:28 PM
DAVID GAGNARD's Avatar
I usually don't beleive all those calculators either, too many varables, but with that said,this is what I found.......
calculator says I am losing 2.23 hp at peak rpm
actual dyno results: I'm losing 3 hp at peak rpm with air cleaner on vs. no air cleaner
In this instance, it is accurate, at least in my case!!!!!!!!!!!!!!!
DAVID GAGNARD
Old 10-23-2008, 05:49 PM
SPF1061's Avatar
Calculator says I am losing 0.23 hp. Dyno says I am losing 0.00.
Seems pretty accurate in my case.
