Old 09-10-2009, 01:37 AM
Cobra Make, Engine: DRB - 351w Stroked to 427
Default Free Play in Jaguar positrak (3.31) Diff
I have had my Jag positrak diff fully rebuilt by Jag mechanic but I'm concerned about the amount of free play. What degree of movement should I expect when rotating the rear 17 inch rim.
Old 09-10-2009, 11:07 PM
When you are rotating the wheel you are picking up backlash and also clearance on the diff output spline plus posi gear clearance. About 3/8" at the circumference of the tire would not be unusual.
Mike Bontoft
cwiinc.com
Old 09-11-2009, 12:36 AM
That freeplay is also the primary reason you should never "dump the clutch". Best to let it out until you feel everything get tightened up, all that slop is taken up. Hold the clutch right on that "edge" and when the light turns green, GO! That avoids the hammer impact to the gear sets which leads to all kinds of broken stuff.
Old 09-13-2009, 08:47 PM
Thanks guys
From what you say the "free play" I have is probably normal
Old 09-22-2009, 07:17 PM
Danr55's Avatar
If you don't like it, I have a 3.54 Posilok differential I want to sell.
Dan in Arizona
CCX3209
