02-20-2009, 04:48 AM
Attachment Test
Attachment Test. Failed when I tried it in a regular post.
Still won't upload and it is only 31KB. Just says Attachment not uploaded.
02-20-2009, 01:18 PM
Beam Me Up Scottie
MA
Sorry - you flunked the test. Get off the testing area and back to work.
Warren
02-20-2009, 02:41 PM
That often happens when you try and upload an attachment of a picture that you have ALREADY used as an attachment in a different post.
Try changing the size slightly and give it a different name.... changing the name only will not get around this error.
03-10-2009, 08:52 AM
Testing to see if I can link to a PPS file.
http://www.slideboom.com/presentatio...Fantastic_Trip
Ok that worked.
Warren,
That is not the Attachment Feature that I am referring to. You just linked that picture from the gallery.
Ron: This is the first time I have been back here since I tried the Attachment and I never saw your post. Thanks for the information and the one I was trying back then was one that is in one of the locked threads that I can't delete. I have been trying to keep my attachments and gallery pictures to a low level and I deleted a lot of old attachments. Thanks for the information.
Reason: To Add Note to CW
03-24-2009, 02:01 AM
Post time test. Mine is off since they have changed the time they set the darn clocks ahead and I don't know which time zone to use.
Ha, first guess. I had to change from Pacific Time to Mountain Time U.S.and Canada.
Reason: Checking time of post
05-20-2009, 04:28 AM
Attachment test of 34KB Jpeg file. 5-20-09.
This is the message that I get on any attempt to attach any picture.
Teddy 2-19-07.jpg:
Upload of file failed.
05-20-2009, 06:33 AM
Interesting... I can upload a .gif file, but not a .jpg.
Very strange...we'll look into it
05-20-2009, 06:38 AM
Thanks Ron. I hadn't tried a Gif file. I thought that maybe some of the old attachments that I had to leave in because they were in locked threads may be affecting my ability to upload an attachment. I deleted almost all of the old attachments to see if that helped but it didn't.
05-20-2009, 06:43 AM
I tried some of mine and got upload failure as well.
05-20-2009, 09:00 AM
Administrator
Wa
testing....Made a change to the database and seems to be working.
05-20-2009, 09:10 AM
..still fails for me with JPGs
05-20-2009, 01:18 PM
Trying my JPG:
Teddy 2-19-07.jpg:
Same results. File is just 35 KB.
While we are on this is is possible to have one of you delete the old attachments that I can't because they were in threads that got locked down and are long gone. I would like to have the space they take up, and the threads no longer exist except maybe in the archives.
05-21-2009, 04:38 AM
Just checking to see if it is working this morning. Nope!
AG00021_.GIF:
Upload of file failed. 15Kb file size.
I can't seem to attach any kind of file. It must be something in my CP, but I don't see anything that is wrong. But I see other posts with attachments in them. Also CW can attach GIF files and I can't.
05-21-2009, 07:53 AM
OK
Let me try it ...
This is a picture of something....
"Let's roll"
"Be part of Something Good
05-21-2009, 08:34 AM
Clois,
Your's worked great. I haven't been able to attach anything since Brent put the limit on the amount of space you have for attachments and I was over it. So I started deleating a lot of mine that had been in there for years to make room and when I hit those that I couldn't delete, I left them in. Then when I got all of the old ones out that I could I can't attach any kind of file.
05-22-2009, 03:18 AM
Ok another try.
05-22-2009, 03:26 AM
Another try as I had three failures in the first one. This picture failed the first two tries and then attached on the 3rd try.
Ok Brent, I can get it to attach a JPG picture about one time out of three or four attempts but it won't attach a GIF file of any size.
05-22-2009, 08:27 AM
Administrator
Wa
Still trying to figure tis out....Haven't given up.
05-22-2009, 08:39 AM
No problem. I appreciate the help and now I know for sure it isn't anything that I am doing wrong. It does seem strange that some people have no problems with any type file and CW had trouble with JPGs but none with GIFs, and I can't post a GIF of any kind and the JPGs will work about once out of four tries now.
05-24-2009, 06:16 AM
Just checking to see if I can attach a GIF this morning.
Nope, and the JPG also fails to load. Tried 4 times and decided it just wasn't going to take either of them.
Reason: Didn't work
