Old 01-05-2010, 03:24 PM
Z-linkCobra's Avatar
Default Blinker switch?
Just wanted an idea of what most have. Do you use a column mount or dash mount toggle switch for the blinkers?
Old 01-05-2010, 03:27 PM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Column with self-cancelling. Its not for the purist, but it is safe and reliable.
Old 01-06-2010, 05:39 AM
cman46's Avatar
Cobra Make, Engine: Shell Valley, 302 with NOS
Column with self cancelling. I have the horn hooked up to the H/L beam switch on the lever and incorporate a latching push button switch in the dash left of the column. In this town I use the horn more than the high beam. Colin
Under Promise and Over Deliver!
Old 01-06-2010, 07:53 AM
Thanks guys...I appreciate the responce.
Old 01-06-2010, 08:56 AM
PurpleVenom's Avatar
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
I used this unit - http://www.signaldynamics.com/products/Modules/turn.asp - then bought a momentary on-off-on switch for turn signals and a momentary push button for e-flashers. Works great and keeps an "authentic" look to the dash with the switch and costs a bit less than the column mounts. Trust me, you will want the self canceling feature. Can't tell you how many miles I've driven with my blinker on.
Old 01-07-2010, 05:25 AM
I always laugh at the people driving down the highway with their blinker on...lol...then I realize thats why that last guy that passed me was laughing...lol. I just havent found a cloumn with a blinker switch that I like. I want to run the column mount self canceling so I need to keep looking for the right column.
Thanks again guys
Gene
Old 01-07-2010, 05:39 AM
cman46's Avatar
Take a look at the column and blinker assembly Shell Valley sells. It is under the accessories section on their site. Also a lot of different colums are available from the Street Rod Boys parts sources like Parr and Speedway. That unit that Purple Venom covered in his post is pretty trick. Personally I kept it for future reference. All for now. Colin
