Like Tree4Likes
  • 1 Post By CoralCobra
  • 1 Post By Tommy
  • 1 Post By CHANMADD
  • 1 Post By gthompson
Old 12-13-2015, 05:56 AM
CoralCobra's Avatar
Cobra Make, Engine: 347 Stroker, RHS Alu. heads, Dual Quad set up. Mild cam
Default It will never be "fixed"
Don posted something on Facebook the other day that got me thinking. What is the one thing on your Cobra that you have spent hours trying to fix or get right and is still not fixed or "right." I have quit a few for this list but I am going to go with my:
Throttle Cable. Replace 4 times, multiple brackets and stretched cables, etc, etc.
What's yours. Pics add to the story.
Texasdoc likes this.
Old 12-13-2015, 07:27 AM
DanEC's Avatar
Leaks - I finally decided cardboard underneath was less stressful than constantly chasing gaskets to repair an occasional drip - that inevitably returns or shows up somewhere else. As long as they are small and don't make a mess on the bottom that I can't wipe up with a paper towel every few months - I'll live with them.
ERA 782 Running
Old 12-13-2015, 09:19 AM
Tommy's Avatar
My training as an engineer and pilot tells me that there is always a root cause for every problem. When the same part fails more than once, there is usually some deeper root cause at work (e.g., poorly designed or constructed part, inadequate part for the application, incorrectly installed part, stress placed on failed part by some other incorrect part, etc.). If I don't fully understand why the part failed, I accept that it is very likely that the new part will fail also.
Sometimes I find that the root cause is harder or more expensive to fix than the part that failed. Tires and mechanical points fall into that category. In that case the failed part is considered worn out rather than faulty. Or like DanEC, I simply accept the problem as less troubling than the solution.
I've had cases where I thought I understood the root cause and it turned out I was wrong. But even in those cases, I ultimately discovered what was really happening. I don't subscribe to the concept that some problems cannot be fixed. ... I do subscribe to the position that, as in politics, for every problem there is a solution that is quick, easy, cheap and wrong.
LoBelly likes this.
Tommy
Previously owned EM Cobra
Old 12-13-2015, 09:38 AM
Cobra Make, Engine: FFR fat block tko 600 9"
Sometimes it boils down to replacing the loose nut behind the steering wheel lol. Making tweaks and improvements is one of the most fun parts, besides driving of course. Electric fuel pumps have given me the most grief, now running a Edelbrock mechanical with crossed fingers. No more wine...
If aliens are so smart, why do they always choose to talk to guys named Bubba?
Old 12-16-2015, 07:08 AM
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
Fuel sending units are unreliable and almost worthless. Had mine changed at only 400 miles and still very inaccurate. Using the mileage for adding gas is a pain but part of the beast I guess.
Your ride should not be to get from point to point. It should BE the point!
Old 12-16-2015, 09:13 AM
Leaks ...
Yep, leaks are high on the list. But the tricky thing about these cars is that there are so many little things that are constantly getting out of whack. I've had my car going on ten years now and if I sat down and went through every little thing that broke, leaked, or just didn't work right and that needed to be tweaked, I'd be writing a long, long list. Lights, switches, speedo reversers, gauges, engine stuff, interior stuff, top stuff, nuts and bolts coming loose, tune up issues, wires chafing, headlights, and that's only the stuff I can think of without looking at my logs.
Old 12-16-2015, 09:31 AM
CHANMADD's Avatar
I've had my car going on 27 years......I am in the middle of switching out the tranny and diff......tranny broke ..diff leaks.....changed the radio...(Bluetooth).....buying new wheels and tires....The sidepipes are being replaced ......a new look for the next 30 years......wait I've changed the interior about 5 times during the life of the car too.....still loving it ......nothing like driving this car ....nothing.......😈
jhv48 likes this.
Old 12-16-2015, 10:07 AM
cycleguy55's Avatar
I have a remote oil filter mount that leaks. I have tried different filters (Purolator, Wix, Motorcraft) and they all seem to leak at the gasket. Using an oil filter wrench to tighten them doesn't seem to provide any benefit. Oil pressure never goes above 75 PSI, so that shouldn't be the issue. The only thing I can figure is perhaps there's a scratch somewhere on the mount that allows the oil to seep - but I have yet to find it. Will probably replace the damn thing in the spring.
Brian
Old 12-18-2015, 03:16 PM
gthompson's Avatar
Cobra Make, Engine: CSX 3020 Competition, 427; CSX 4385 Aluminum Body, 427; CSX 2096, 289
Don's Cobra and Don's Truck for the last 6 months!
bwcobra15 likes this.
