Old 12-17-2002, 09:58 AM
Cobra Make, Engine: Custom Built Classic Motor Carriage T 5 Z tranny still in the making ..
Angry Man I am tiered of poor Quality
I purchased lower control arms coil over shocks and upper control arms all from the same place Speedway .Just under a $1000.00 Come to find out the lower mount of the shocks Do not fit the lower arms .The bolts that goes thru the shock are 7/16 and the bolt that {holds } the shock to the Lower A arm is 1/2 .Hmmm .So I spoke to Marty and his responses is make it work its all we have . So that means its up to the purchaser to redesign there product to make there parts work correctly .I know being in the business that this is common but I also know that Quality comes first as well as Customer Satisfaction .It just seems it accurse more and more and it is just Very sad that a product would be sold as a kit and it doesn't even FIT ! Just needed to get this off my head .ck out the pick .
T
King Cobra
ALL IT TAKES IS TIME AND MONEY !!!
God Bless us All
Old 12-17-2002, 10:00 AM
Tongue Pirate's Avatar
Sounds like someone who doesn't care much about their reputation IMO!
Hyde D. Baker
Old 12-17-2002, 10:49 AM
dscott's Avatar
They should have told you about the size difference. But then the salesline people are just that. Order takers. You can change the bearing in the shock to a 1/2" and drill out the spacers or buy 1/2" bushings, looks like the cone bushings are too big anyway and need to be trimmed.
Don
Old 12-17-2002, 01:58 PM
kountzecobra's Avatar
Tony, isn't this fun? Your control arms are made by Speedway and the coilovers are made by Carrera. I had the same problem with mine, but I will have to look and see what I did. Next you will probably find out that the Carrera coilover shock and the spring is a little too short. I removed the shock mount plates and welded a new plate flush with the top of the spring pocket. Also made a 1/2 " spring spacer because I ran out of threads on the adjustment collar. I seem to remember I changed out the bearings in the shocks for 1/2" ones I got from Carrera. I don't like the steel sleeve bearings because they are noisy, so I used the Nylon ones. This sounds like a lot of trouble but really isn't. You will find out a lot of things are not going to just bolt-on this car like they should. Especially if you mix and match parts from different manufacturers like I did. If you need part # or anything else let me know. Later.
David Shelton
Lone Star Gashole!
Old 12-18-2002, 12:47 PM
Angry !@#$%$&^%$#!@^
Your right D Scott He should have said you will need to do some modification or I do not the right shock to sell you !
Kount Z HAHAHA ! Email me Send me some picks of yours please and part no.s and a phone # I wanted to chat since I can only peck on the computer .
T
King Cobra
God Bless us All
Old 12-18-2002, 10:14 PM
Talking Ck this out
Ok KountZ you were right on the spring being short but ck this out .We put the left lower arm on the right side and the Right on the left so that the lower shock mount would be on the top to make contact with the coil over .I found some bushing to make the shock work just need to make some spacers .
T
King Cobra
God Bless us All
Old 12-18-2002, 10:43 PM
Turk's Avatar
Send a message via Yahoo to Turk
mustangmendez
You need to reset the clock and the date in your camera. It is NOT Dec.19 2002 yet. It will be later on, but not yet!
We don't miss a thing in here.
TURK
OBAMA IN in 2012
Old 12-18-2002, 11:18 PM
Cobra Make, Engine: Lone Star Classics, LS 427, 302 cid @ 370 HP, T5 and 8.8" rear end, 99.99% complete
Default Re: Man I am tiered of poor Quality
T
Turk
I did a lot of custom and different things with my Cobra build. Lone Star did a good job with their stuff for the most part but some of the other big names. Ford Racing Parts, Edelbrock, Moroso gave me fits. In the catalog and tech data not a word about this is different, this won't fit that, be careful about this etc. Then the vendors response "We can't plan for all the possibilities or worse yet " So send it back or even worse "I don't know". I got the "I don't know" many times from big names. I think the problems may be with poor personnel, who don't give a rat's ass about the client. At Edelbrock I got the run around on valve to piston clearance problems. When I finally showed up in Torrance CA with the heads I got to talk to one of the TOP GUNs who figure the problem out in 10 minutes and the solution was some obscure push rods and lengths. A trip to Torrance to get action???
Cobra Chuck
Old 12-18-2002, 11:46 PM
Looks like it may work Tony. I couldn't do that with mine because I am using the stock struts and the strut mounting plates wouldn't line up with the control arm reversed. Keep up the good work!
David Shelton
Lone Star Gashole!
Old 12-19-2002, 07:24 AM
Wink
Turk Your a Bad Boy ! GO to your room ! HA HA AHA AHA
Cobra Chuck I know even the Big Name brands have parts that do not fit correctly but it is sad that you would have to spend your time having to travel to get a problem solved where are those big guns when the average tech an not help ?I bought a paint booth so called Quality and ran in to multiple problems but the worst was that one exh fan motor keep burning up .They claimed the problem was the electrical wire was to long but when it came down to it .All in all the left fan blade had a straighter fin there for causing it do drag and increase the amp draw and burned the motors up .So with all that I ended up getting 1/2 my money.It just seems to happen more and more .
T
King Cobra
God Bless us All
Old 12-22-2002, 06:07 PM
Talking Now we are getting some where
Wow we are getting closer every day getting over some of the bad stuff and running in to more problems but thats just part of building a Cobra Kit car.Here I am throwing a fit !HA HA
King Cobra
God Bless us All
Old 12-23-2002, 12:22 PM
bwcobra15's Avatar
Cobra Make, Engine: Hurricane 427 Cobra #HM2008, Craft Performance 427w 600hp/600tq, TKO-600 close ratio, original Smiths gauges, lucas switches
Send a message via Yahoo to bwcobra15 Send a message via Skype™ to bwcobra15
Hmmmmm.... reminds me of why I want to buy an "already put together - no assembly required" Superformance
Bob Worley
Hurricane HM-2008 build is done!! (for now....)
Craft Perfomance 427W / 600hp / 600tq - TKO600
I love it and I need it I bleed it ~ Yeah it's a wild hurricane ~ Alright, hold tight, I'm a highway star!!
Old 12-26-2002, 11:36 PM
Cobra Dude's Avatar
Cobra Make, Engine: CMC, Supercharged Ford 5.0 & all the toys.
Tony,
Gotta be careful with these mix-and-match parts. I got mine from JPL, and they fit very well. What I had done was to call a bunch of different control-arm vendors and ask them to fax me a tracing of the part, and other dimensions, which many did. JPL's fit nicely, were excellently welded, even included a tool for drill alignment, and were priced well.
Be careful about swapping left side to right, etc, as IIRC, the arms are not symmetrical. You could throw off the caster, etc, although with the arm flipped upside-down as well, you may be okay.
I'm using Carrera's as well, so if you have spring-mount probs, perhaps you have the wrong spring? Compare the part # on mine.
-Neil.
   www.VEIsystems.com
CMC Cobra, Ford 5.0, EFI, Vortech supercharged, T5Z, 8.8 rear, MII front, 4-wheel discs, A/C, stereo.
Old 12-27-2002, 12:34 AM
decooney's Avatar
Default Re:
Mustangmendez,
Sorry to hear about the trouble... people/companies like that won't stay in business for long selling junk with boards like this out here. I almost ordered parts from Speedway once, I won't now.
Also, if those upper control arms require Chrysler type screw-in ball joints, when you flip them upside down and reverse them, sometimes the side of the ball joint will "hit" the round end edge/cup of the control arm where the ball joint mounts in to. You can check this with the shocks/springs out and by moving the suspension up and down full/top to full/bottom to make sure its not hitting. Also, the geometry will be way off if you flip them around like this. If all else fails, just send them the parts back anyhow, and demand a refund in writing stating "parts do not fit". If they don't refund you, usually a complaint/phone call to a local business Beaureau official can get things turned around. Good Luck.
Duane
Old 01-19-2003, 08:29 PM
Talking Ed 1, CountZ, Joe G, Cobra Dude,and more
Ok Guys here is what I did to my Cobra this week end not much but its something .Boy Cobra Dudes parts fit good on mine . I also started building a new shop for my toys 24x31 ft next to the 60 x 60 Shop .Whew cant wait to see my Cobra in there Done or undone in there .
T
King Cobra
God Bless us All
Old 01-20-2003, 11:44 PM
Default Re: Ed 1, CountZ, Joe G, Cobra Dude,and more
T
What's the color of the Cobra? Do you have a color number? It is gorgeous.
Cobra Chuck
Old 01-21-2003, 11:57 AM
Post Cobra Chuck
Which one ? Cobra Dude cobra is a special mix called Mustang Mendez Red Pearl .I do the paint mixing as well .RCS will be a solor yellow a std color but the stripes are so black you cant see the bottom .My Cobra HMMMM who knows .
King Cobra
God Bless us All
Old 01-21-2003, 12:03 PM
Ed Csoltko's Avatar
Cobra Make, Engine: FFR1358 (Sold)
Wink Way to Go!
Tony's got a rolling dune buggy. Keep up the good work, we'll be cruising together soon.
Texas Cobra Club 2004 VP
Old 01-21-2003, 12:05 PM
Talking New Cobra Den
Here is the Start of my Cobras snake den a whopping 26ft deep 31ft wide next to the Shop, hope to get it done before the September party just another thing on my list for this year .
T
King Cobra
God Bless us All
