December 2025
Old 12-31-2002, 01:33 PM
fubar's Avatar
Default I need more compression.
I have a 351w and have a 10-1 compression ratio. I would like to have it at about 14/1. What options do I have and what do they cost?
Mark A. Monroe
Fubar
Old 12-31-2002, 01:39 PM
RACER X #99's Avatar
$600 for a set of domed pistons.
With 14-1 compressiopn you only have one option., $5.00 a gallon race gas.
Hope this helps.
Cranky
Old 12-31-2002, 01:47 PM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Better know what your piston to valve clearance is before you go buying parts.....
Jack
XSSIVE .....
Old 12-31-2002, 02:01 PM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
Is this for the street or track? High comp. motors tend to run hot on the street, not reccomended. You will also need to change the cam.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 12-31-2002, 02:02 PM
Cobra #42's Avatar
Cobra Make, Engine: Superformance Roush 427
Fubar, Are you going to make the Austin Trip in February ?? db
Don Barnes
Driving Instructor
texasdrivingexperience.com
Texas Motor Speedway
Old 12-31-2002, 02:12 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
You do have another option.
Leave the CR alone, fill the tank with Premium, and enjoy the ride.
Old 12-31-2002, 02:21 PM
Todd Hedges's Avatar
Cobra Make, Engine: ERA 427SC w/428 & Richmond 5-speed Car 611.
I have read through various DVSFII posts that most of the Gasholes could increase the compression by merly sitting atop the carb. after a night of raki and Steak & Lubes' finest foods.
That should boost compression right off the gage and may require O-ring heads similar to those of the booster rockets on the shuttle.
...."they say I'm crazy, but it takes all of my time."
Old 12-31-2002, 02:47 PM
Jeb's Avatar
Jeb Jeb is offline
I'm a bonehead!
assuming your internals can handle it, you could increase compression rather simply by installing some form of supercharger. Probably wouldn't even need to be much of one at that. Maybe from a 3.8 T-Bird?
I'd also be wondering why you would like to do this. Maybe there's another way to get to where you want to be than drastic increases in compression.
They serve also who stand and wait
Old 12-31-2002, 03:30 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Thumbs up I'll go along with Jeb
Supercharger. And $5.00 per gallon race fuel
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 12-31-2002, 04:00 PM
The Royal Rhubarb
Cobra Make, Engine: ERA #495,427SO, Stroked
Send a message via AIM to ERA600hp
Talking Fubar
I'm running a 13:1 compression
I've never had a over heating problem!!
Just keep up with you timming and everything will be great!!
The Royal Rhubarb
Life is GOOD!!
Old 12-31-2002, 04:41 PM
fubar's Avatar
Default Thanks for the help.
Thanks for the advice you guys. I have been told that I need new pistons (by Norwood) He recommened J&E's at 150 each. Kinda pricey but it's nice to know you got the good stuff.
Mark A. Monroe
Fubar
Old 12-31-2002, 04:49 PM
Jeff Frigo's Avatar
Shop around. $150 / piston is way too much.
Jeff
Mark Donahue
