03-21-2003, 05:15 AM
Cobra Make, Engine: BDR #42, 425HP 347 - NASA TX, CMC #55 Mustang Road Racer - Legends 37' Chevy Coupe #43 Oval Racer - Honda CRF450R(I'm afraid to race it), 95' Black Lighting Daily Scooter
I agree Ryan. A local machine shop fixing your damage is the cheapest way to go at this time. Build a Rip-Snorter later.
Boudy
03-21-2003, 05:30 AM
Renegade Nuns on Wheels
Oh
Looked it up
All new hypereutectic pistons, all new bearings and rings and all news gaskets $320 from summit. Why replace one cast piston?
03-21-2003, 05:41 AM
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Your Royal Highness....
You said:
"...Flyin Freddie, Good answer, and I though you were just anouther pretty face??..."
Well, yeah, I am....but that's just my 'hook' to get ya in...then I pounce!
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
03-21-2003, 07:53 AM
Cal
You can replace just one piston, but it will be on the same kind that has allready proven itself to be too weak for your motor. Better hope it is heavier than the other pistons as well, so you can remove material and bring it into a close balance. You will need to rehone the cylinder or the new rings won't seal right. You can cut corners, not bother measuring clearances, or "measure" with pastigauge, restretch rod bolts over and over again, but those motors generally don't go many miles, what did you get 1200?
03-21-2003, 08:16 AM
Cobra Make, Engine: FFR3200, Carbed 351W, IRS, TKO600 RR
I got 1200miles because of a stupid error that I don't care to mention....
I am rehoning, replacing all pistons, rings and rod bearings but as far as balancing etc...the old one wasn't balanced so I probably won't do it this time....it was running great until I screwed it up!
Thanks for the help,
Ryan
03-21-2003, 08:24 AM
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
see thread : Official TCC Presidential Nuts.
hahahah
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
03-21-2003, 08:30 AM
Ryan...please reconsider the balancing...
...please, Ryan, reconsider the balancing, won't you?
Your old engine was running fine, alright, but that was with another set of pistons! New ones might not be as close as your old set, and could actually be much worse. If you're going to use all new pistons (the correct plan, by the way!) then why not spend a little more to help insure you'll get a lot more miles out of your re-build?
I know you're looking to do this as economically as possible...hell, who on this website DOESN'T understand that desire?!? But, not balacing the rotating assembly could actually wind up costing you a lot more in the long run.
I fully agree with your plans, so far...rehoning, new pistons and rings, new rod bearings...all sounds right. I'd replace the rod bolts, too, and I wish you'd have your rods checked, too, to make sure the big end's still okay...probably is, but how do you know? I'd also look at your mains, too, just because you can while you're in there. No sense in realizing you have a problem after you button everything back up.
Man...please reconsider your decision on balancing, won't you...?
Flyin_Freddie
03-21-2003, 08:33 AM
I guess I'm the only guy around these parts that thinks sometimes it's OK to just do the MINIMUM.
With a baby on the way, funds a little short, here is my take on REALITY.
Buy one piston that matches the rest of them and put the new slug in the bore! Why you gonna change rod bearings? You said the motor was recently rebuilt and detonation was the problem. Man, don't make a mountain out of a mile hill. Deglaze the bore, (a light hone) and ONE new piston. Intake and head gasket and bam, your back on the road.
It will be fine! By the way, I don't like hyperuretic pistons. Use standard or go "race", not in between.
Ernie
03-21-2003, 09:08 AM
Cal
If he had a problem with detonation, his rod bearings will be hammered. Look at the shiny spots in the middle of the uppers. A balance job will cost about $100, just a tad more than the gasket set.
03-21-2003, 09:46 AM
I guess it's also possible the other pistons have been damaged and just haven't cracked,,,,,,YET. But how going to balance without doing a complete tear down? And it does not appear that "balance" was an issue in this case anyway.
Leave the motor in the car. Drop the pan, pull the head, check the bearings for flat spots, shove in a new piston, cross your fingers and drive it "nice" until your get your money together. Basically a "pit stop" approach so you can finish the "race".
Ernie
03-21-2003, 09:53 AM
Cal
He has to pull the motor out, he is goint to rehone the cyl. It actually saves time to pull the motor out if you are going to pull the pan and a head, usually. Besides, if he had enough detonation to break a piston, I would be really curious about the other pistons and their rings. Unless I am missing something, this is not ocurring during a race, no sense in doing a half-@ssed job that will just need more expensive redoing shortly down the road.
03-21-2003, 10:00 AM
Don't have to pull the motor to rehone. But your point is well taken, I would want to check the rings and ring lands on all pistons.
And of course if your going that far, you might as well pull the motor,,,,,,,see what happens when you try to do it "right", now it's getting all complicated. LOL
Ernie
Ernie
03-21-2003, 11:34 AM
I only had detonation on the one piston because of a sharp edge due to damage...
03-21-2003, 12:03 PM
03-21-2003, 07:28 PM
Tx
Ryan,
I'm lazy. I didn't read every reply. I did see the engine had only 1200 miles on it. You said The crack was caused by detonation Due to damage. What kind of damage? Can we see a picture? Are you sure that is the root cause? I have nitroused the hell out of stock 1973 cast 302 pistons with no failures. Just sounds kind of odd is all.
Steven
All my ex's live in Texas
03-22-2003, 03:46 AM
tx
Cobra Make, Engine: specialty motor car (out of existence) 351w 405 hp. c6 auto.
this thread is starting to get a little nutty, what don you think
I don't suffer from insanity, I enjoy it.
Bob Taulbee
03-22-2003, 01:16 PM
 Oh yeah, I'm sure of it...
03-23-2003, 05:57 PM
Cobra Make, Engine: FFR 3668 5.0, Windsor Jr., E303, Cobra intake.
New Forged slugs
Check www.dallasmustang.com for TRWs. I got a set for about what a set of Hyperwhatyamacallits would have cost. I paid about $1500 for align boring, fully balancing installing the pistons etc on my 302. It would have been about the same price to get a shortblock crate motor, but I know this one is balanced right.
Dave
