Old 10-30-2003, 04:33 PM
Cobra Make, Engine: Lone Star Classics, 302
Question Name that handling phenomenon
Today, as I was accelerating through a sweeping curve, a truck stopped in front of me. When I let-off the gas, the car 'twitched' as if trying to oversteer. I haven't experienced this before, although I have long thought my rear springs were too stiff.
I tried to force this reaction on other streets...with the same results. I guess I've always just continued accelerating until straightening-out.
Anyway, I figure there is a name and a solution for this (besides driving more conservatively). So I welcome any information by those more educated than me.
FYI - I don't have any anti-sway-bars on the car.
"ANYBODY can BUY a car"
Old 10-30-2003, 04:43 PM
392cobra's Avatar
6th Generation Texan
It's called Trailing Throttle Oversteer.
From Panoz Racing School-
" A handling tendency that results in an oversteer condition caused by abrupt lifting off the throttle while cornering, and thus abruptly tranferring weight to the front of the car."
Easing back into the throttle will move the weight to the back.
Be carefull.
Old 10-30-2003, 05:04 PM
Cobra Make, Engine: Lots fo different cars that change all of the time
Wink RIGHT ON FRED
THAT "UPSETS" THE CAR...KINDA LIKE IF YOU ARE FURIOUSLY MAKING LOVE AND YOU SUDDENLY SLOW DOWN, IT "UPSETS" YOUR PARTNER
OH BY THE WAY, "SLOW IN-FAST OUT" ALSO MIGHT UPSET YOUR PARTNER IF YOU ARE MAKING LOVE
JAY
ALL I WANT IS A NICE SWEET NYMPHOMANIAC DEAF MUTE THAT LACTATES TEQUILA
Run & Gun participant 1998-2005
Old 10-30-2003, 05:35 PM
kountzecobra's Avatar
Jay, since when did any of us care what our "partner" thinks?
David Shelton
Lone Star Gashole!
Old 10-30-2003, 05:36 PM
Something to consider if it was a "twitch" only (and a feeling of looseness or vaugeness in the rear end) is the possibility of a loose bushing, bracket, etc. in the locating linkage for the rear end...might be worth a check.
Ken
Old 10-30-2003, 06:02 PM
KobraKarl's Avatar
Good call, 0077,
Loose components in an IRS rear end can take you from toe-in to toe-out in a split second ,...and it feels very weird!.....I would think you would have noticed that on the straight away as well though.
Trail-throttle over steer almost "ditched " me once right after i got my car........scared the crap out of me.
KK
Old 10-30-2003, 06:54 PM
wizard's Avatar
Cobra Make, Engine: West Coast 460, Performer Cam & Intake, Edelbrock 750cfm Carb
Been There. Done That. Got the soiled undies to prove it.
"Nobody gets to see the Wizard. Not Nobody. Not Nohow.
Old 10-30-2003, 07:00 PM
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
WIZARD,
Post those words of wisdom on the thread by Edley in the lounge..
Definitely words to live by....
Old 10-30-2003, 07:03 PM
wizard's Avatar
Cas
Please Clarify
Wiz
Old 10-30-2003, 07:12 PM
wizard's Avatar
Cas
I got it. Excellent topic.
Why doesn't that thread come on the home page after a new post? I haven't seen it before.
Wiz
Old 10-30-2003, 07:34 PM
Cobra #42's Avatar
Cobra Make, Engine: Superformance Roush 427
Good Job Fred, You were paying attention in class, you didn't learn that at drivers dull edge event. Inside joke, LOL, db
Don Barnes
Driving Instructor
texasdrivingexperience.com
Texas Motor Speedway
Old 10-30-2003, 10:14 PM
John A. Simpson's Avatar
Cobra Make, Engine: KMP 393 $27 S.O. bored and stroked to 482
Default Trailing throttle oversteer
If its not severe it can be used to tighten your line slightly, if you are a little too fast into a corner. If you don't expect it or it is great you can end up with a nickname like mine.
Sideways
Old 10-31-2003, 12:21 AM
And often the reason you see the "spin outs" in an SCCA event. Lifting abruptly for the next cone.
My solution is simple, thats why they call me "Cone Killer".
Ernie
Old 10-31-2003, 07:47 AM
Rocksnake, Does it have an IRS? If so, check the toe in. I run more toe in then most, 3/16 in. It seems to settle the rear and make it less twitchy. Also, generally, if you jump into or out of the throttle in a cobra in a corner, you can get oversteer. If its too stiff of a spring rate, it should step out under acceleration as well as when you lift. Good luck, scott.
Old 10-31-2003, 08:12 AM
Thanks for the information. I checked the control-arms, and everything appears to be tight. This is an 8.8 'live axle', and yes, it did scare the crap out of me. Sufficit to say, I was not conforming to the posted speed-limit.
